Yes, for sure it is. Google “how to get current month in javascript”
Using a building as a solar collector
In 4 season countries solar radiation heat varies over the seasons. During winter, even during a fully sunny day, the sun will not provide significant passive heating of buildings. However, from spring to fall the passive heating of buildings provided by the sun can cause waste of energy when both indoor heating and indoor cooling systems are running at the same time, which happens especially during spring and fall. Rather big savings can be achieved by proactively adapting the amount of heating used to the available incoming solar thermal energy. Thanks to OpenHAB and our community it is possible to use the solar energy forecast and electricity spot price to proactively turn down heating spenditure when there is surplus heat available from the sun.
The script below is my attempt at maximising the use of passive solar heating in a 4 season environment. No solar thermal collector or solar panel is used. Instead, the capability of the building itself to absorb solar thermal energy is exploited. The script relies on the OpenHAB Solar Forecast PV add on with a free solcast account and @masipila’s solution presented in this thread. Register a free account at solcast and install the Solar Forecast PV add-on and you should be good to go!
Edit: The script below was updated 1st of August to correct a couple of bugs.
console.log("Item heatingHours before solar inluded", items.getItem("heatingHours").state);
//Get energy forecast from Solcast
solarEnergy = items.getItem("Solcast_PV_Plane_Forecast_Tomorrow").state;
// calculate reduction coefficient from virtual solar panel max power and forecasted power
q = solarEnergy/1000;
console.log("Reduction coefficient:", q);
// replace JS dumb month numbering scheme starting from 0 with proper names for the months
var months = ["January","February","March","April","May","June","July","August","September","October","November","December"];
// figure out current month
var d = new Date();
var currentMonth = months[d.getMonth()];
// Set max heating reduction hours, k, based on current month
if (currentMonth == "March" || currentMonth == "October") {
k = 0.5;
} else if (currentMonth == "April"|| currentMonth == "September") {
k = 1;
} else if (currentMonth == "May" || currentMonth == "August") {
k = 2;
} else if (currentMonth == "June"|| currentMonth == "July") {
k = 3;
} else {
k = 0;
console.log("It's winter");
console.log("It is now",currentMonth,"so max heating hour reduction thanks to solar is",k,"hours");
// calculate heating hours correction using the reduction coefficient and max reduction hours
m = q*k;
n = items.getItem("heatingHours").state - m;
console.log("Item heatingHours after solar included",items.getItem("heatingHours").state-m);
if (n < 0) {
n = 0.01;
// update heating hours item
items.getItem("heatingHours").postUpdate(n);
Recently my Nibe F1226 heatpump has the two Shelly1 relay switches to switch between the 4 SG Ready modes. General question, can I break something on the heatpump when I would block the compressor for one whole month as long as the temperature is always above 5 degrees Celcius? This way I would like to save costs when I’m not in the house for one month.
As I mentioned in my post 13, I disclaim all warranties and everybody is responsible for what they do with their devices.
A couple of things you might want to consider:
Nibe F1226 does not have a built-in vacation mode like for example F1245 so you need to do this yourself like you are now thinking. You might want to search from other forums what exactly does the vacation mode do in F1245 and then try to mimic that.
I would not switch off the pump completely. The valves might get stuck if they are unused for an extended period of time.
Regarding the heating, I would just drop the desired temperature from the Nibe menus.
One gotcha: F1226 has a setting “Minimum temperature for outgoing water” (should be menu 1.9.3). If my memory serves me well, the default is 22 celsius or at least that was the value it was set to me after installation. If compressor is blocked and the temperature drops below this, then Nibe will use electricity directly to ensure that the temperature does not drop below this. So you might want to consider adjusting this to a lower value like 17 or something.
Regarding domestic hot water, you can configure AUX1 to “block heating of domestic hot water” and that should do it. Remember that when you get back, there is a risk of legionella bacteria because the temperature of domestic hot water has dropped to the optimal temperature for the growth of legionella bacteria. So you do want to start the periodic increase as the first thing when you come back.
Thank you very much for the very useful information.
Currently I have on my Nibe F1226 the following configuration for “holiday” mode:
- Menu 1.9.1 “Heating curve” 4 (normally 9)
- Menu 1.9.3 “Minimum temperature for outgoing water” = 15°C (normally 20)
- Menu 4.2 “Operation mode”=“auto”
- Menu 4.9.2 (Auto mode setting): “Stop heating” = 12°C (normally 17), “Stop additional heat” 10°C (normally 15) → this will ensure that when the “average outdoor temperature” is greater than these values, no heating will be done
- Menu 5.4 “AUX1” = “SG Ready A”
- Menu 5.4 “AUX2” = “SG Ready B”
During “expensive hours” now SG Ready mode “Blocking” (A: Closed, B: Open) is used to block the “compressor” and “additional heating”. This doesn’t block “hot water production”.
In future I might consider trying out the following instead of the SG Ready modes:
- Menu 5.4 “AUX1” = “External tariff blocking” → This can block “heating”, “additional heat”, “compressor”, and “hot water production”
- Menu 1.9.2, “external adjustment” = +5°C
- Menu 5.4 “AUX2” = “External adjustment” → This can “boost” the heating curve offset so that the house can be heated a bit more just before I come back home.
Thanks again, it is a lot of fun for me to try to understand the behaviour of the heatpump a bit better I will try to understand the vacation mode in F1245 like you mentioned as well.
I found out setting the heating hours to zero is not a good idea, it confused the script, so here is an updated version that ensures heating hours never go to zero. The rest of the scripts will average the result to zero.
// calculate reduction coeffficient from virtual solar panel max power and forecasted power
const month = ["January","February","March","April","May","June","July","August","September","October","November","December"];
const d = new Date();
let currentMonth = month[d.getMonth()];
if (currentMonth == ("March"||"October")) {
k = 0.5;
} else if (currentMonth == ("April"||"September")) {
k = 1;
} else if (currentMonth == ("May"||"August")) {
k = 2.5;
} else if (currentMonth == ("June"||"July")) {
k = 4;
} else {
k = 0;
m = q*k;
if (n < 0) {
n = 0.01;
A hardware question, I own a nibe F1245. I read several posts using a relais to set the aux input. But as we’re saving energy, anyone investigated using an optocoupler to set it? I Imagine voltage and current for the input aren’t that high.
Nibe AUX pins use 3.3V low voltage.
Ok, and probably.no.more than a few mA. Well in range for an optocoupler. I can’t be the first to think of this, anyone tried it?
I have a Nibe 1245 and used a Chinese solid state relay for some time with no problems. Changed it to a wireless mechanical relay for convenience reasons.
Hi I’m planning to develop a “real” Entso-E Binding add-on using Java. And maybe later FMI API binding. Any ideas how it should work on openHAB Things, Channels, Items, etc.
See
Which was superseded by Allow sending historic states and forecasts by J-N-K · Pull Request #3597 · openhab/openhab-core · GitHub
Markus
Is there an easy way to get the average spot price for the forecasted day? I would like to have the value in an item to use it in a gauge.
Edit:
Sorted this out by myself: Copied the function in nibe.js that calculates average temperature and replaced fmi_forecasted_temperature with spot_price. Works like a charm.
I have implemented this in the graph that shows me the spot prices and control values, see screenshot below, which shows the average price as a dotted line.
The YAML looks like this:
component: oh-time-series
gridIndex: 0
item: spot_price
itemStyle:
color: "#4E6AC4"
lineStyle:
opacity: 0.5
markLine:
data:
- label:
distance: -150
type: average
name: Sähkön spottihinta
step: middle
type: line
xAxisIndex: 0
yAxisIndex: 0
Will Markus’ cool “ground source heat pump” javascripts work directly in OpenHab 4.0, which now uses GraalJS/ECMAScript 2022? I wonder if it’s safe to upgrade OpenHab 3.0 to OpenHab 4.0 for that?
I haven’t had time to test that yet myself but I would also be super grateful for this information if somebody has tested this…
Hi folks
I’m on V4.0.3 and haven’t encounterd any problem yet, use multiple scripts for diffrent stuff, EVcharger,P Pool heating x2, Pool filtration x2, Nibe heatpump.
Hi
I am on OpenHAB 4.0.2 and it works and is stable. 5/5
I’ve revived my old EntsoE binding for testing if you’re interested:
Anyone else having trouble getting day ahead spot prices for Finland today? I can not download them.
Edit: It would be nice to have this automated, so that the rule retries with e.g. 30 minute intervals until the spot price can be fetched. Any ideas how to implement?
Edit2: @gitMiguel s EntsoE Binding Thing gives “Offline” error when the Entso-E does not provide data. This could be used to recognize failure.
Edit 3: I still have not figured out how to get this to retry upon failure.
