Here is a little tutorial on how I integrated my new ceiling fan into openHAB.
Because I wanted a modern and simple looking fan I could not find a suitable one hat could be controlled by a Sonoff iFan03.
Instead I bought a Faro Pemba wich comes with a simple 433 MHz remote.
So I bought a Sonoff RF Bridge 433 MHz as a gateway between openHAB (via mqtt) and the ceiling fan.
I flashed the RF Bridge with Tasmota.
Next step was to learn the RF commands like described in the Tasmota Wiki.
Here is the result of my openHAB configuration:
fan.items
Switch RF01_Reachable "RF01 reachable [%s]" <network> {mqtt="<[mosquitto:tele/rf01/LWT:state:MAP(reachable.map)]"}
Number RF01_RSSI "RF01: RSSI [%d %%]" <switch> {mqtt="<[mosquitto:tele/rf01/STATE:state:JSONPATH($.Wifi.RSSI)]"}
String RF01_Verbose "RF01: MQTT return message [%s]" <signal> {mqtt="<[mosquitto:tele/rf01/INFO1:state:default],
<[mosquitto:stat/rf01/STATUS2:state:default],
<[mosquitto:stat/rf01/RESULT:state:default]"}
// Deckenventilator
Group gCeilingFan "Deckenventilator" {alexa="Endpoint.Fan"}
Number CeilingFanSpeed "Deckenventilator Geschw." <heating> (gCeilingFan) {mqtt=">[mosquitto:cmnd/rf01/Backlog:command:0:RfRaw AAB01503080154029E2BE82809090909091818181818091855; RfRaw 0],
>[mosquitto:cmnd/rf01/Backlog:command:1:RfRaw AAB0150308014A028A2BDE2809090909091818180918181855; RfRaw 0],
>[mosquitto:cmnd/rf01/Backlog:command:2:RfRaw AAB0150308015E02942BDE2809090909091818180918091855; RfRaw 0],
>[mosquitto:cmnd/rf01/Backlog:command:3:RfRaw AAB0150308015E02942BDE2809090909091818091818181855; RfRaw 0],
>[mosquitto:cmnd/rf01/Backlog:command:4:RfRaw AAB0150308014A029E2BD42809090909091818090918181855; RfRaw 0],
>[mosquitto:cmnd/rf01/Backlog:command:5:RfRaw AAB0150308015E029E2BD42809090909091809181818091855; RfRaw 0],
>[mosquitto:cmnd/rf01/Backlog:command:6:RfRaw AAB0150308015402942BDE2809090909091809181818181855; RfRaw 0]",
alexa="RangeComponent" [supportedRange="0:6:1",
presets="1=@Value.Low,3=@Value.Medium,6=@Value.High",
friendlyNames="@Setting.FanSpeed,Speed"]}
Switch CeilingFanPower "Deckenventilator Power" <fan_ceiling> (gCeilingFan) {mqtt=">[mosquitto:cmnd/rf01/Backlog:command:ON:RfRaw AAB0150308015E02942BDE2809090909091818091818181855; RfRaw 0],
>[mosquitto:cmnd/rf01/Backlog:command:OFF:RfRaw AAB01503080154029E2BE82809090909091818181818091855; RfRaw 0]",
alexa="PowerController.powerState"}
Switch CeilingFanRotate "Deckenventilator Richtung" <movecontrol> (gCeilingFan) {mqtt=">[mosquitto:cmnd/rf01/Backlog:command:ON:RfRaw AAB01503080154029E2BDE2809090909091818181809181855; RfRaw 0]",
autoupdate="false",
alexa="ToggleController.toggleState" [friendlyNames="@Setting.Oscillate,Richtung"]}
fan.rules (Thanks to @jeshab for this)
rule "CeilingFan Power Command"
Item CeilingFanPower received command
if (receivedCommand == ON)
CeilingFanSpeed.sendCommand(3)
else
CeilingFanSpeed.sendCommand(0)
rule "CeilingFan Speed Update"
Item CeilingFanSpeed received update
if (CeilingFanSpeed.state == 0)
CeilingFanPower.postUpdate(OFF)
else
CeilingFanPower.postUpdate(ON)
fan.sitemap
sitemap fan label="fan"
Frame label="Deckenventilator" {
Switch item=CeilingFanPower
Selection item=CeilingFanSpeed mappings=[0="aus", 1="langsam", 2="2", 3="mittel", 4="4", 5="5", 6="schnell"]
Switch item=CeilingFanRotate
Text item=RF01_Reachable
Text item=RF01_RSSI
Text item=RF01_Verbose
It can be controlled with Alexa.
The downside of this solution is that there is no feedback from the fan to the bridge/openHAB.
So your smart home does not know if you turned on/off the fan with the remote or if the fan did not respond to your commands.
I did not test the light feature.
Some info about the device:
Model: Faro Pemba 33471
Remote: RH787T
