I´ve set up an ESP8266 to control my TV using Infrared Signals which I´ve decoded from my Samsung Remote. I already have set up a switch in Opnehab to turn the TV On and Off, works like a charm.
Now I want to add more Buttons, like Volume up, Down, Channel Up, Down and so on. In general I would just configure an item for each Task, but I have noticed that I get into Trouble with Alexa, because this identifies every button as a single device. So the Command, “Alexa, TV On” and “Alexa, TV Off” confuses her, she doesn´t know which device she should use…
So I thought I must only create one single TV Item and control every task with this item. I stumbled upon mappings, but I don´t know if this is the right path I should take. And if, I have no idea how to combine mappings with the http Binding…
I hope someone could assist me here, thanks in advance!!
Unfortunately I cannot tell you much about the ESP Sketch because I flashed it using ESPEasy ([ESP8266] Cheap IR remote - Share your Projects! - Home Assistant Community) . In fact the ESP receives a http command like http://192.168.1.222/control?cmd=IRSEND,SAMSUNG,E0E040BF,32 where E0E040BF is the IR command to turn the TV on.
So now I have a lot of those http commands (like volume, channel, mute…) but when I add them to my home.items every button is recognized as a single device by Alexa.
There is a Xiaomi Vacuum Robot Binding that uses Mappings for several commands and is still recognized as one device by Alexa, but I don´t know how to combine mappings and the http Binding.
You can try to send the commands via mqtt. Here is a link that uses mqtt for controlling a fan with Home Assistant but I’m sure, with a bit of tweaking, it can work with OH. https://github.com/robbiet480/Seville-MQTT
