Control XPS poolheaters
Hi guys,
i ordered me a new pool heater a few days ago. While i had to change the connection cable, i opened the electrical box of my XPS 70 heater. There is the following wiring diagram inside the box:
Now i want to make this thing smart by adding something like a Wemos D11 or similar to get information about the temperatures and set temperature and turn it on and off. I am able to design circuit boards and program the arduino code eventually. But i need someone with the detailed technical insights of the onboard PCB.
Hey,
Good luck, it’s worth it. Please check out if my project is compatible
Hey, do you get it run?
I would Like To Switch it on/off smart.
Do you have some Information for me To get it done?
Thank you
Markus
