Benny_Boy
(Benny Boy)
June 15, 2018, 9:58pm
1
I start in home automation. I installed openhab on a Raspberry Pi 3 and started reading and learning about it. I chose to use the Z-Wave protocol.
I’m planning to buy a Aeon Labs Aeotec Z-Wave Z-Stick USB adapter, Gen5 Z-Wave Plus - ZW090.
I would then like to find ways to control my ceiling fan to allow it to decrease the intensity of a speed every 10 minutes until closing.
The model of my ceiling vilter is Savanna 52 in. LED Indoor Brushed Nickel Ceiling Fan with SkyPlug Technology.
The exact model of the controller is FAN61T-4SP1.
By then I’m going to tackle a simpler challenge and incorporate a simple dim light bulb.
Thank you!!
Rob_Pope
(Rob Pope)
June 15, 2018, 10:06pm
2
That controller looks like it uses 433Mhz rather than Z-Wave. Take a look at the RC Switch library (which I believe has a version for the Pi) but check compatibility first.
Benny_Boy
(Benny Boy)
June 15, 2018, 10:15pm
3
Rob_Pope:
RC Switch library
Hi Robe, I read my remote complies with Rss-210 Issue 8. How I can validate that and make sure about compatibility ? Thank you!
Benny_Boy
(Benny Boy)
June 15, 2018, 10:17pm
4
Benny_Boy
(Benny Boy)
June 15, 2018, 11:02pm
5
Rob_Pope
(Rob Pope)
June 16, 2018, 6:25pm
6
I don’t know for sure whether it will work. The best option is to try it and see. You can buy a 433Mhz receiver for the Pi cheaply so you can try to learn the sequences. It’s worth adding that 433Mhz is not the same as RFID.
A quick google and I found this which should get you started http://www.instructables.com/id/Super-Simple-Raspberry-Pi-433MHz-Home-Automation/
Benny_Boy
(Benny Boy)
June 18, 2018, 1:29am
7
Rob_Pope:
RC Switch library
Hi, I order it and I will update the thread with the result of my test
Thank you!
Benny_Boy
(Benny Boy)
June 23, 2018, 4:54pm
8
Hi, I start to document my stuff. Normaly I speak french so I use my natural language. I have a problem about the noise I see then I use pilight-debug. Someone can help me with that please.
[11:49:55] root@openHABianPi:~# pilight-debug
Press and hold one of the buttons on your remote or wait until
another device such as a weather station has sent new codes
The debugger will automatically reset itself after one second of
failed leads. It will keep running until you explicitly stop it.
This is done by pressing both the [CTRL] and C buttons on your keyboard.
--[RESULTS]--
time: Sat Jun 23 12:31:16 2018
hardware: 433gpio
pulse: 34
rawlen: 48
pulselen: 207
Raw code:
567 48 168 43 150 38 147 44 149 46 137 44 161 44 149 36 242 29 166 50 319 33 236 43 144 49 142 41 151 46 148 49 145 45 142 40 147 43 147 50 218 46 221 39 191 40 139 7053
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 222
pulselen: 372
Raw code:
219 40 171 44 166 45 159 41 158 44 158 26 290 47 159 44 141 49 198 37 188 50 148 43 157 46 159 41 159 46 159 50 137 40 165 45 152 46 147 44 258 31 179 47 141 44 140 28 256 34 163 44 160 43 163 44 156 47 158 43 161 44 155 43 155 42 152 49 225 41 201 45 141 45 133 38 199 37 178 48 139 45 140 48 148 49 175 46 148 53 145 46 142 62 198 50 128 38 257 41 156 49 127 46 135 34 228 39 144 39 149 48 142 43 149 50 144 45 154 50 151 42 149 47 145 49 128 45 229 32 178 46 135 47 126 43 197 36 188 51 132 47 145 48 144 46 147 44 143 41 154 49 154 43 147 52 127 50 213 44 182 59 124 48 139 49 206 49 182 50 137 46 180 40 159 50 146 49 150 42 158 39 159 46 152 54 136 48 204 32 269 40 154 48 203 50 193 47 146 47 131 42 151 48 143 41 153 47 141 43 153 49 226 138 259 44 198 47 135 51 128 12680
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 372
pulselen: 1623
Raw code:
292 51 147 21 232 24 213 43 180 41 188 41 168 36 184 40 175 40 314 41 174 44 249 35 229 47 176 43 230 32 224 46 172 42 160 41 172 42 174 42 167 44 165 44 160 39 165 45 144 35 256 33 173 44 145 49 225 32 195 41 161 40 167 47 148 41 163 42 160 44 165 48 315 40 164 41 251 32 191 49 144 46 237 44 273 42 184 45 182 44 170 37 185 38 194 37 196 47 172 45 144 33 290 44 181 44 157 47 229 33 218 43 177 45 168 46 174 41 185 40 175 46 172 42 176 45 163 48 234 31 215 44 162 42 189 37 244 44 162 42 178 45 171 43 169 45 178 49 169 43 163 41 168 46 178 32 259 46 166 49 138 39 208 34 212 43 166 44 167 40 168 43 183 43 172 46 170 44 161 46 165 53 218 37 203 46 156 48 141 40 217 38 173 50 138 42 168 47 165 51 145 38 165 42 156 41 154 43 164 48 130 35 238 34 169 48 140 44 167 34 221 36 169 48 153 43 165 42 159 45 162 44 161 47 161 43 151 45 154 53 239 38 198 48 145 46 163 31 235 41 163 47 151 46 147 46 149 47 159 47 156 47 159 44 146 49 147 44 239 45 195 52 148 45 138 31 233 39 169 48 150 44 155 47 160 46 160 50 150 46 141 43 155 51 148 54 132 36 232 42 164 45 143 46 166 37 216 33 158 42 150 46 147 47 156 48 166 44 158 42 158 47 148 47 147 48 132 36 237 40 161 46 146 54 210 65 173 47 151 46 151 47 153 49 135 41 153 49 137 42 160 52 135 42 150 52 212 43 190 54 129 49 164 58 181 47 160 45 137 53 208 55193
--[RESULTS]--
time: Sat Jun 23 12:31:17 2018
hardware: 433gpio
pulse: 34
rawlen: 218
pulselen: 399
Raw code:
315 45 202 38 212 40 202 38 206 42 207 37 209 43 230 38 201 38 205 41 207 41 211 41 204 39 205 39 202 39 203 40 324 42 203 41 204 40 194 35 205 38 201 36 198 40 191 42 203 40 202 43 191 42 198 41 204 39 196 40 184 35 192 44 190 42 196 37 193 44 198 43 187 40 189 40 189 43 189 40 219 43 189 42 192 45 195 42 222 39 206 42 190 39 194 41 199 38 197 33 208 37 198 39 189 40 195 44 192 40 194 38 195 38 192 40 196 43 196 40 187 43 189 40 195 39 204 40 199 41 195 36 203 39 206 38 202 39 196 39 200 40 198 38 193 42 224 48 208 41 201 42 197 47 195 38 200 38 210 37 201 41 191 33 201 42 245 30 312 32 286 35 219 42 192 36 196 21 214 38 196 34 212 36 195 40 192 42 196 43 193 38 203 43 202 42 209 41 186 39 182 38 190 41 183 43 182 41 180 40 187 48 304 36 325 68 154 13597
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 226
pulselen: 1748
Raw code:
172 71 170 74 171 86 154 64 177 70 177 73 165 71 174 64 171 66 170 63 155 58 172 66 170 57 181 63 180 62 191 63 187 66 188 57 183 61 189 66 192 67 198 51 207 70 172 64 188 68 172 62 197 65 188 65 168 60 187 68 194 57 187 78 165 61 172 71 167 69 163 60 167 66 166 81 165 69 162 68 177 65 175 74 172 70 182 72 174 76 174 67 173 72 177 66 185 71 172 66 173 71 170 70 168 65 169 59 179 73 171 61 182 69 180 76 167 78 203 64 181 68 177 69 180 63 184 65 175 67 175 64 180 63 176 62 174 67 174 67 167 59 165 57 180 68 167 58 192 75 173 65 183 64 186 68 173 68 169 62 182 69 177 66 188 65 179 68 189 66 187 70 182 64 186 70 180 67 182 64 181 69 173 65 199 67 172 68 182 72 179 63 184 64 191 70 182 62 189 70 163 73 161 72 153 61 182 59 169 81 161 75 171 71 168 76 162 61 167 72 155 74 148 71 165 59439
--[RESULTS]--
time: Sat Jun 23 12:31:18 2018
hardware: 433gpio
pulse: 34
rawlen: 47
pulselen: 1915
Raw code:
77 165 77 195 64 171 69 162 68 174 63 171 67 167 62 172 65 165 65 165 72 164 79 158 67 172 66 174 73 166 81 167 65 171 72 153 61 164 84 153 71 157 80 174 50 173 65140
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 475
pulselen: 399
Raw code:
499 71 189 60 174 64 195 71 180 72 173 66 179 64 194 72 178 65 185 66 180 75 173 66 178 63 186 64 185 63 178 61 188 65 187 59 190 68 177 58 298 56 190 78 170 74 180 69 161 62 178 60 171 56 176 61 183 64 186 67 170 72 164 70 173 60 181 75 172 75 231 61 176 68 180 69 208 59 180 70 172 75 171 65 169 66 179 61 186 63 184 64 186 69 176 67 182 67 187 65 193 65 189 78 172 59 182 66 181 64 179 67 181 70 182 62 182 73 183 73 179 61 180 61 185 67 183 60 180 64 175 73 172 81 196 64 182 73 175 65 175 62 176 61 166 59 181 62 182 70 172 67 180 67 180 69 178 66 179 80 165 64 178 67 180 62 189 68 179 62 183 69 178 70 175 68 172 75 179 75 172 70 177 71 170 71 174 66 158 55 181 58 166 61 176 64 170 71 172 75 203 87 40 182 67 164 68 170 72 163 73 160 74 168 69 181 69 179 66 181 65 182 61 177 66 176 79 169 65 161 64 163 59 172 66 181 73 169 67 183 63 169 59 182 73 171 68 182 65 166 62 315 65 172 66 168 62 180 61 167 75 175 70 167 65 178 63 177 73 173 72 165 61 172 70 157 68 168 63 169 59 184 62 175 62 312 72 182 60 193 64 176 63 180 68 175 67 184 69 178 66 174 69 176 67 172 75 168 73 154 64 171 74 169 66 165 79 161 73 161 72 176 71 168 74 151 69 150 57 167 76 164 63 180 84 155 71 161 72 161 77 153 67 158 59 175 75 161 70 168 62 180 68 172 71 177 72 165 66 162 62 160 71 159 76 157 68 168 74 162 77 166 73 174 67 172 70 177 73 161 64 169 59 172 69 174 69 169 67 162 73 170 68 180 72 168 76 167 81 173 76 158 71 162 66 174 64 164 69 159 71 164 71 163 73 165 79 156 70 163 57 179 73 164 66 164 64 170 64 170 65 178 67 153 58 178 53 180 74 168 66 172 69 170 67 168 66 163 80 155 71 157 68 205 43 189 71 153 68 156 77 156 89 149 77 157 84 183 79 171 79 158 67 162 13572
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 482
pulselen: 1407
Raw code:
199 60 196 67 205 59 208 49 202 43 228 59 208 62 203 61 200 59 198 60 215 63 199 53 194 53 203 55 199 56 191 56 194 55 208 40 198 55 187 57 197 55 192 51 206 57 196 65 186 56 199 63 202 61 193 61 199 62 201 60 202 66 201 65 202 61 196 64 192 60 192 87 199 61 176 56 191 60 187 61 182 58 194 62 181 67 176 69 177 56 199 71 186 57 184 74 182 55 198 72 177 53 197 62 196 60 187 59 191 54 198 57 188 62 190 59 189 60 193 54 191 59 186 62 187 66 182 60 193 63 186 63 193 59 192 55 194 59 196 58 193 54 194 54 194 56 186 59 192 63 188 58 214 54 194 62 201 64 181 53 194 50 213 55 503 64 202 56 177 70 173 64 176 62 188 62 205 69 184 67 184 59 192 69 186 68 179 63 178 60 196 75 174 63 173 65 185 62 184 108 204 65 172 53 185 65 169 63 176 62 178 64 192 67 173 69 171 65 176 73 167 69 171 56 186 62 173 65 175 82 187 71 163 53 188 73 183 53 192 72 175 62 179 73 174 65 178 60 185 53 236 65 180 66 174 65 188 53 188 67 177 63 179 64 180 75 168 68 180 68 179 67 184 66 181 60 195 62 178 61 186 71 181 71 185 67 176 70 190 65 179 70 181 68 179 61 178 66 191 60 187 65 185 63 178 64 180 69 178 60 175 51 192 71 168 63 172 70 177 65 180 68 169 62 177 71 176 69 183 68 187 73 175 66 180 75 170 61 184 67 183 67 171 67 175 80 158 70 162 69 157 64 174 65 178 68 170 70 172 80 163 63 171 76 162 79 160 79 150 63 167 62 183 69 173 78 169 68 173 73 165 72 169 67 178 69 177 72 172 71 182 71 190 45 217 87 157 69 175 62 182 63 172 63 176 65 176 63 169 62 172 60 177 72 166 66 162 65 180 70 184 64 175 67 172 66 172 69 175 80 164 73 165 58 167 63 171 77 170 69 171 65 177 62 171 63 176 72 179 72 173 72 170 66 169 70 171 67 163 54 174 74 159 73 172 68 171 63 176 70 168 66 158 60 167 62 179 58 184 1768 176 47869
--[RESULTS]--
time: Sat Jun 23 12:31:19 2018
hardware: 433gpio
pulse: 34
rawlen: 423
pulselen: 897
Raw code:
65 178 67 188 64 187 75 170 58 183 73 174 70 176 61 186 75 185 70 183 66 184 68 183 68 185 67 188 69 183 67 175 64 184 66 192 60 188 66 181 60 188 60 189 63 183 58 193 67 187 67 186 63 187 63 175 58 197 69 183 67 202 64 179 63 182 59 192 64 193 64 180 66 182 71 185 66 185 67 180 68 179 66 188 62 193 62 189 60 192 64 185 60 188 72 180 61 187 68 174 71 177 63 186 65 187 66 180 67 179 68 186 62 183 65 191 60 190 68 180 62 175 64 177 76 187 67 175 69 180 70 176 65 173 72 170 65 163 64 170 67 161 81 160 73 170 71 163 65 175 65 171 63 180 66 164 60 173 57 176 71 178 62 177 61 182 68 173 60 190 65 179 68 173 75 174 68 170 68 183 67 165 60 168 57 176 58 186 67 177 67 193 60 185 71 162 69 194 49 184 71 167 65 173 71 179 68 177 69 177 74 183 72 166 59 184 67 164 53 173 59 172 68 171 66 169 63 168 59 184 72 196 64 183 60 191 63 192 59 190 63 194 68 186 67 187 60 180 80 165 62 174 63 174 68 169 80 208 70 164 74 160 66 162 68 162 55 174 78 160 64 168 66 178 77 167 66 171 68 147 64 179 63 168 73 161 70 160 64 176 70 167 71 177 67 172 70 156 62 168 60 167 62 176 77 165 71 164 73 166 70 175 76 159 70 164 67 153 69 167 67 160 68 177 65 196 66 213 56 212 50 210 55 217 59 176 66 162 55 172 73 165 74 164 72 168 68 164 69 165 62 161 71 166 67 170 66 174 72 158 70 166 66 206 54 187 62 174 69 170 75 168 77 156 79 152 60 179 59 169 84 156 77 164 62 173 74 170 75 163 77 172 66 162 67 161 60 169 78 154 71 157 71 157 75 147 68 150 72 150 80 155 75 162 69 172 75 158 76 152 66 156 30499
--[RESULTS]--
hardware: 433gpio
pulse: 6
rawlen: 508
pulselen: 711
Raw code:
352 69 198 71 204 69 189 62 197 62 182 67 180 69 186 59 189 56 192 60 195 65 186 69 183 67 191 69 178 62 187 69 186 64 181 62 176 70 181 63 178 74 168 66 192 71 181 60 182 63 187 63 181 62 205 66 189 70 178 63 192 71 189 73 182 57 179 63 180 63 180 65 186 67 186 67 194 56 200 60 189 63 186 65 190 63 183 65 178 62 190 64 179 60 195 86 176 61 183 64 187 61 196 66 179 63 185 63 177 56 192 77 181 63 187 65 184 73 202 58 187 67 185 64 182 55 191 63 185 68 182 64 187 71 177 64 184 68 171 62 183 71 184 60 187 64 189 60 184 65 184 68 175 74 175 69 194 60 352 72 162 58 165 65 174 70 172 64 172 68 167 78 158 63 158 58 178 67 164 67 173 58 189 60 190 68 165 69 170 72 163 68 178 73 170 61 174 57 182 59 177 56 187 77 163 69 176 64 177 60 186 59 194 60 185 57 186 68 176 61 176 55 176 50 188 67 172 56 189 64 171 61 170 71 164 62 184 72 187 70 209 76 166 69 184 65 174 58 187 57 173 71 164 64 169 66 164 69 157 63 168 68 169 68 171 63 181 60 180 64 175 66 177 62 164 60 171 63 168 72 169 72 169 62 171 64 174 75 168 66 169 75 158 57 168 66 170 76 158 65 305 61 172 62 159 71 142 61 167 68 158 69 162 72 161 72 178 65 157 68 158 58 193 49 176 71 153 71 158 58 172 72 158 59 167 72 164 73 161 64 167 71 167 83 159 67 162 72 157 55 165 70 166 64 178 62 173 69 169 62 171 69 158 67 172 64 170 88 155 63 170 68 171 74 163 77 164 76 164 67 157 63 171 56 259 68 162 61 168 67 165 64 168 77 169 70 155 63 179 67 177 68 170 62 176 70 156 79 217 64 153 59 169 62 163 69 162 67 171 63 167 58 169 75 159 59 162 67 153 59 165 64 172 60 157 66 160 68 165 60 171 80 157 71 143 72 140 73 156 84 153 76 171 66 174 76 144 71 151 59 156 70 162 76 156 70 155 77 138 56 162 4325 214 78 167 55 181 68 167 64 175 58 172 71 188 67 179 68 173 61 175 63 168 59 175 60 163 60 171 75 164 58 183 63 169 57 262 24188
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 49
pulselen: 1869
Raw code:
68 176 62 188 58 187 71 179 60 195 63 193 54 206 68 181 65 185 68 184 67 185 67 171 69 179 70 175 71 172 70 176 71 174 59 186 73 167 60 174 72 159 52 177 79 164 63 176 63575
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 297
pulselen: 1159
Raw code:
173 68 171 60 188 67 169 61 176 68 179 65 175 67 176 72 162 64 182 72 168 70 178 65 185 68 181 60 195 70 196 70 171 59 198 72 188 68 164 61 171 66 172 71 169 63 161 59 173 58 165 58 173 66 174 73 167 67 160 61 169 68 164 58 178 69 163 60 172 68 169 76 156 85 157 63 154 63 174 74 164 61 168 65 167 68 169 65 174 71 155 61 179 65 163 73 154 61 191 67 173 63 182 70 167 69 169 81 163 64 159 70 151 66 157 65 167 70 169 70 179 74 195 75 178 67 181 67 181 68 181 69 177 68 168 72 166 59 166 61 172 63 169 70 169 76 167 78 161 60 192 65 161 65 176 74 165 64 169 66 155 66 182 76 181 57 180 69 174 66 171 64 173 69 174 65 177 62 178 67 168 59 169 61 176 59 171 69 169 70 164 69 180 61 182 66 176 74 170 74 178 64 179 66 182 53 191 68 146 59 180 72 159 65 169 74 167 67 177 73 167 61 176 78 164 68 151 65 167 72 174 63 187 73 163 63 170 67 164 72 171 67 176 78 160 68 157 79 156 68 160 72 159 64 168 67 167 70 166 67 162 66 169 59 165 59 180 69 165 70 173 75 156 71 145 99 161 75 155 60 164 87 43 178 86 47 181 80 156 67 173 70 166 91 47 178 39430
--[RESULTS]--
time: Sat Jun 23 12:31:20 2018
hardware: 433gpio
pulse: 34
rawlen: 368
pulselen: 983
Raw code:
194 58 181 56 182 56 184 60 179 56 183 67 180 55 177 61 195 66 172 58 187 63 185 60 209 66 170 56 192 60 187 58 188 56 186 57 188 63 182 59 195 72 184 63 178 65 186 64 183 73 186 59 177 69 167 63 173 65 162 57 175 61 173 61 177 60 178 66 180 67 175 68 172 65 179 65 190 59 167 77 215 61 198 66 189 64 188 63 205 68 188 59 185 65 175 67 178 70 177 67 182 67 175 61 187 68 186 71 187 67 185 65 180 65 183 72 184 73 176 65 182 64 183 64 186 69 189 60 198 66 186 67 184 62 189 66 193 61 177 67 179 56 193 60 187 63 184 65 183 64 189 54 210 61 193 67 174 58 208 51 195 69 180 63 180 67 178 65 180 65 186 59 186 64 185 69 177 70 192 65 181 61 182 67 181 68 187 67 179 72 178 65 183 70 184 69 179 71 179 64 182 72 186 66 186 63 179 64 183 68 181 66 185 73 172 71 188 67 180 69 186 66 181 74 183 68 181 68 170 78 239 62 177 71 164 66 171 72 185 45 191 60 176 70 167 77 163 64 159 59 170 63 177 69 171 65 174 64 180 66 177 73 176 64 178 75 175 65 189 72 168 59 185 66 181 68 181 69 179 72 167 81 195 69 184 73 174 63 187 72 178 71 179 71 170 70 162 66 176 70 165 61 174 60 178 69 172 69 174 71 171 67 177 74 164 67 173 64 178 55 182 74 175 65 174 64 159 58 181 69 157 68 179 76 169 62 176 72 172 72 173 69 168 68 172 61 186 58 207 59 223 54 222 50 231 58 218 69 162 57 175 65 159 76 165 85 160 33438
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 336
pulselen: 209
Raw code:
351 69 202 58 179 66 191 64 179 77 201 62 200 62 190 59 201 65 192 68 181 61 190 65 192 67 179 66 190 66 300 66 180 66 188 62 175 69 172 63 190 61 197 69 180 62 182 64 182 65 181 64 184 66 184 70 180 70 177 66 186 64 207 49 206 65 179 64 184 64 191 63 189 61 181 64 170 62 172 64 176 69 165 66 160 66 174 69 173 60 183 67 169 71 177 72 169 62 179 63 176 59 176 80 168 65 165 68 171 55 180 63 179 69 178 70 175 69 188 70 180 66 184 68 176 63 179 75 163 63 178 65 185 62 181 66 177 66 196 68 192 66 176 60 198 48 194 67 177 61 179 68 180 68 185 63 178 78 171 60 177 65 176 63 172 58 184 64 163 67 169 73 175 68 178 74 180 69 168 68 175 67 169 67 175 67 175 68 170 72 159 59 172 66 173 68 170 72 175 59 182 74 167 65 198 64 181 73 160 61 190 64 171 65 177 67 147 60 164 68 167 80 211 64 179 72 171 63 197 72 167 70 164 74 162 81 149 69 167 79 161 75 165 74 151 56 184 64 171 65 177 68 171 72 175 73 170 63 186 67 182 65 170 63 174 71 168 65 172 67 171 52 191 64 172 61 177 73 169 65 170 63 177 68 175 58 184 73 172 69 175 66 172 71 157 58 165 70 173 61 174 60 172 68 173 68 177 66 178 79 172 71 190 78 174 63 174 78 160 66 165 77 162 68 167 63 364 72 169 61 173 68 157 58 176 7115
--[RESULTS]--
hardware: 433gpio
pulse: 7
rawlen: 404
pulselen: 290
Raw code:
188 66 182 71 182 70 172 58 186 69 171 66 211 59 222 58 217 52 232 52 175 59 173 62 185 64 180 76 159 68 171 62 174 67 178 68 173 64 185 65 177 70 183 67 187 66 243 67 177 71 175 73 178 75 173 62 187 71 173 62 189 84 167 70 177 69 168 65 186 66 174 61 187 61 186 71 180 69 175 57 187 66 181 65 189 61 187 71 214 54 208 64 198 58 187 65 185 56 186 59 192 61 185 65 175 69 175 76 177 65 169 68 180 68 172 64 175 64 176 66 174 66 173 62 170 51 192 66 175 70 169 68 166 73 168 70 177 67 179 67 182 70 165 69 164 72 147 63 160 81 152 75 167 67 193 74 157 67 178 66 177 64 167 58 160 61 173 74 158 73 169 67 169 69 179 60 193 67 177 65 185 66 182 71 177 67 181 74 179 71 176 71 174 64 187 74 175 64 176 72 168 65 165 66 162 61 174 65 172 71 182 63 173 63 170 68 184 73 170 75 187 68 177 64 173 70 177 74 156 64 158 66 170 65 168 78 162 73 168 75 165 64 176 68 168 63 169 64 159 56 180 70 158 73 171 75 169 70 168 73 165 70 174 64 172 68 159 64 175 69 161 73 163 71 156 71 171 77 168 79 162 67 154 67 154 1907 249 4847 281 73 174 58 185 61 186 62 182 53 205 61 175 65 180 65 176 65 187 63 174 65 183 66 188 63 184 62 186 60 183 64 195 66 181 61 188 67 181 65 183 70 174 67 187 76 172 73 169 60 183 66 184 67 185 69 169 67 193 72 181 63 185 71 178 67 183 83 169 63 172 86 169 69 189 64 174 70 161 67 165 68 153 67 166 55 219 64 173 83 161 72 165 78 160 65 177 73 174 70 173 70 170 79 167 69 173 65 161 55 179 62 178 68 283 9871
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 288
pulselen: 155
Raw code:
184 72 184 68 169 62 176 101 197 58 187 55 178 70 175 65 185 69 196 57 192 63 176 64 185 69 181 67 181 62 182 63 183 58 193 71 184 64 187 64 201 54 196 62 191 59 187 57 184 61 186 64 186 59 186 62 191 65 191 69 183 68 188 63 187 65 185 56 193 65 185 68 182 61 190 60 189 62 180 67 185 65 199 60 182 56 188 70 188 62 198 46 192 58 188 67 187 60 193 63 184 60 181 67 176 70 183 62 188 62 179 55 197 66 184 67 194 68 180 66 195 62 188 56 199 61 184 51 194 68 175 60 191 75 161 59 188 70 179 64 187 60 182 77 163 62 194 58 237 53 250 55 225 54 208 74 166 69 174 67 180 62 194 63 189 65 186 57 202 63 189 61 186 60 188 66 185 65 187 69 179 64 189 64 180 66 183 59 183 64 187 62 186 64 182 64 184 67 189 61 189 64 195 80 173 69 177 63 185 62 214 60 200 62 191 59 193 58 189 58 179 57 176 63 182 63 185 65 183 64 189 71 182 69 177 66 174 65 179 73 182 68 180 66 183 69 175 66 201 55 203 56 188 58 200 62 188 64 202 62 194 72 190 51 194 70 169 63 180 70 166 69 175 68 192 64 173 58 181 77 172 58 188 76 163 68 164 5296
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 270
pulselen: 961
Raw code:
171 65 187 68 173 70 171 65 183 63 184 68 179 59 185 65 181 68 196 65 181 68 187 70 175 62 172 71 174 58 182 60 180 53 195 64 178 65 182 62 208 43 198 61 184 65 177 65 181 74 176 63 178 73 178 64 174 69 181 62 180 67 182 64 186 71 182 63 188 62 185 66 178 67 188 66 185 67 192 77 160 60 193 70 187 70 179 63 177 65 183 69 175 75 180 68 181 72 176 70 184 67 175 68 180 66 169 58 176 51 188 61 185 62 175 73 162 70 159 72 166 72 217 43 199 85 151 67 172 71 185 68 170 67 179 71 167 65 175 70 165 71 160 57 176 56 178 65 196 61 189 70 167 65 173 62 181 67 172 63 184 66 176 55 184 61 178 66 170 65 164 64 173 66 174 76 171 60 179 64 170 65 177 71 176 69 177 73 173 64 179 67 179 70 169 67 163 56 179 66 174 61 181 76 170 65 170 69 175 66 173 67 175 70 190 63 189 73 166 68 174 77 161 63 173 65 174 74 155 62 170 69 174 61 175 69 171 62 177 74 164 65 180 70 168 70 158 67 165 66 167 70 170 75 163 80 149 71 162 76 155 79 148 64 164 86 155 75 163 32674
--[RESULTS]--
hardware: 433gpio
pulse: 34
rawlen: 500
pulselen: 483
Raw code:
361 72 198 60 187 68 190 60 195 74 176 59 186 53 217 42 209 70 187 65 185 69 179 70 174 66 174 66 177 60 181 62 195 62 187 71 179 69 177 62 196 63 189 66 182 69 186 76 179 68 181 57 200 79 172 73 181 60 179 63 180 67 169 64 176 71 177 73 162 68 162 63 166 53 180 63 179 65 176 74 169 64 173 73 179 74 171 69 179 67 173 59 195 63 237 49 286 50 247 50 200 61 180 63 201 51 185 65 186 61 180 73 177 77 170 64 180 68 171 66 175 66 189 58 193 71 169 58 192 72 173 62 186 68 181 65 176 67 181 64 186 71 179 74 171 74 173 69 176 70 179 57 186 68 177 59 174 55 189 68 166 60 177 65 175 60 183 80 159 60 198 76 166 61 183 69 187 64 184 69 174 66 173 65 180 76 180 76 179 72 182 68 167 67 174 68 165 69 154 59 177 72 170 71 171 72 172 72 177 67 170 78 162 74 172 74 164 73 164 70 173 73 159 72 153 73 165 70 173 67 177 68 170 64 179 71 205 69 187 64 187 59 197 58 188 59 199 67 192 63 187 59 179 69 171 58 177 79 177 71 178 67 176 69 174 64 175 65 175 67 175 70 174 65 179 61 173 61 179 67 172 59 182 69 166 68 171 68 178 70 172 64 176 69 177 73 169 63 169 70 154 49 200 67 163 69 172 68 167 69 164 55 180 67 176 74 164 74 168 65 164 58 172 68 169 72 167 70 171 69 168 75 172 72 175 77 167 74 165 71 154 87 175 75 154 99 196 82 157 70 199 75 170 76 164 77 164 76 160 70 151 77 156 86 152 67 164 69 194 74 172 69 179 68 175 66 176 73 174 76 179 68 170 69 176 63 162 66 171 62 178 67 167 71 168 68 161 65 171 71 171 67 186 70 171 58 167 59 162 62 174 66 176 68 174 73 164 62 172 66 187 75 164 69 175 71 167 63 162 55 180 65 159 70 173 67 179 73 162 70 174 73 169 73 168 68 156 59 168 72 157 71 165 67 178 66 181 70 164 69 179 80 163 67 179 81 167 66 159 57 164 67 166 85 172 80 149 70 160 69 160 85 158 68 152 69 154 72 145 64 163 78 159 84 149 77 147 67 160 16442
--[RESULTS]--
time: Sat Jun 23 12:31:21 2018
hardware: 433gpio
pulse: 34
rawlen: 472
pulselen: 459
Raw code:
186 62 198 57 200 58 204 61 204 60 190 63 195 60 182 68 199 66 194 66 196 61 181 65 191 50 195 66 189 53 202 62 201 54 209 60 177 55 186 55 196 61 194 55 186 55 189 61 192 57 192 61 191 54 193 60 182 67 180 67 172 66 185 79 168 62 181 74 183 67 179 63 168 64 181 68 176 68 192 69 174 66 184 66 203 67 196 56 191 65 181 65 177 60 188 62 251 48 267 53 246 45 237 60 188 62 191 70 167 60 186 63 180 54 201 66 174 49 191 62 183 59 188 61 177 60 186 64 185 71 177 65 185 57 188 56 199 67 185 66 178 63 178 63 186 68 191 66 180 68 180 68 188 68 183 67 174 58 200 65 192 64 173 68 206 18 208 65 186 63 177 64 181 68 182 68 175 70 176 67 178 66 192 71 175 67 184 65 172 69 182 76 174 64 189 72 167 63 168 58 173 56 183 65 184 63 170 66 173 75 167 74 166 69 179 73 171 66 186 72 179 64 179 70 197 63 183 63 186 67 185 59 186 66 194 63 183 69 177 68 176 66 187 69 174 66 183 65 184 68 192 69 175 59 184 79 173 71 179 87 182 73 185 64 185 59 186 56 198 62 199 66 189 59 197 60 190 66 187 73 164 61 175 68 176 69 181 63 205 65 168 66 180 68 178 61 184 69 175 70 170 72 185 70 177 70 168 68 172 60 172 64 178 66 174 67 171 61 178 65 172 68 161 70 179 71 170 75 176 75 158 73 149 62 249 69 170 67 185 69 169 88 149 80 143 61 164 75 160 64 173 71 172 65 204 69 178 71 178 73 163 64 172 67 175 68 177 75 186 67 179 79 174 79 166 75 167 67 174 67 160 53 169 69 166 72 164 69 175 65 182 70 168 69 171 73 169 67 165 64 166 60 176 79 164 75 161 65 180 70 171 62 181 74 171 71 176 72 172 73 195 72 173 63 173 72 170 73 162 63 160 59 166 67 169 68 173 65 171 75 173 71 170 72 180 78 167 71 182 75 169 62 169 62 171 73 149 65 170 65 163 68 162 63 169 67 156 66 173 68 166 15615
Thank you!
