Inspired by a post from another Forum / GitHub I started to experiment with my coffeemaker.
It has built in support for Alexa, but it’s quite closed source.
What does work right now?
Extracting recipes from the machines
Sending recipes to it.
(Using smartphone/Alexa App an automated start ist also possible, but i did not figure out how to start the recipe)
Sending a recipe: (70ml Espresso)
curl -s -k -d ' {"uid": "00000000-0000-0000-0000-000000000000","creatorId": "22","userId": "33","userName": "Smarthome","name": "Espresso","coffeeAmount": 70,"foamAmount": 0,"milkAmount": 0,"cupSize": 80,"creationTimestamp": 15,"defaultRecipe": 1,"usesHotMilk": 1,"favouriteCapsuleId": -1,"sequence": { "index_0": 2, "index_1": 3, "index_2": 4, "index_3": 0, "index_4": 0 }}' -H "Content-Type: application/json" -X POST https://qbo/brew
Get all recipes stored on a QBO
curl -s -k -H "Accept: application/json" -H "Content-Type: application/json" -X GET -k -s https://qbo/recipes
Get maintenance status
curl -s -k -H "Accept: application/json" -H "Content-Type: application/json" -X GET -k -s https://qbo/status/maintenance
In case you are using the same machine, or if you managed to start brewing from OpenHAB, it would be great to hear about it.
