Hi, so I was able to add all my Philips bulbs into openHAB through Paper UI.
My problem is I’m able to turn my bulbs on and off from openHAB and Homekit but that’s all I can do. I can’t adjust the colour or brightness.
After I added the bulbs I created home.items
file with the following content.
// Ground Floor
// Hall
Switch GF_Hall_Light "Light" <light> ["Lighting"]
// Living Room
//Switch GF_Living_Room_Light "Light" <outlet> ["Lighting"]
// First Floor
// Bedroom
Switch FF_Bedroom_ElectricBlanket "Electric Blanket" <outlet> ["Switchable"]
Switch FF_Bedroom_ElectricHeater "Electric Heater" <outlet> ["Switchable"]
Switch FF_Bedroom_Light "Light" <light> ["Lighting"]
Switch FF_Bedroom_Lamp "Lamp" <light> ["Lighting"]
// Master Bedroom
Switch FF_Master_Bedroom_Light "Light" <light> ["Lighting"]
Switch FF_Master_Bedroom_ElectricBlanket "Electric Blanket" <outlet> ["Switchable"]
// Landing
Switch FF_Landing_Light "Light" <light> ["Lighting"]
After doing this I also created a home.sitemap
sitemap home label="Home 🏡"
Frame label="Hall"
Switch item=GF_Hall_Light label="Light"
Frame label="Master Bedroom"
Switch item=FF_Master_Bedroom_ElectricBlanket label="Electric Blanket"
Switch item=FF_Master_Bedroom_Light label="Light"
Frame label="Bedroom"
Switch item=FF_Bedroom_ElectricHeater label="Electric Heater"
Switch item=FF_Bedroom_ElectricBlanket label="Electric Blanket"
Switch item=FF_Bedroom_Light label="Light"
Switch item=FF_Bedroom_Lamp label="Lamp"
Frame label="Landing"
Switch item=FF_Landing_Light label="Light"
So far everything is working as it should, I can control all my bulbs from Basic UI and from Homekit. What I’m struggling with is changing the brightness or colour of my bulbs. And when I say struggling I mean I can’t do it at all. I know I’m missing something but I can’t seem to work out what it is. Ideally what I’d like is for each bulb in Basic UI to have an On/Off Switch, Brightness slider and colour picker/sliders. And for the same thing to be reflected in Homekit.
Any help, pointers, advice, links to documentation I’m more than likely not finding?
