I am running the latest Openhab3 snapshot build. Openhab is connected to myopenhab.org for using Google Assistant to control my items.
It’s working for my Light (e.g switch on/off, brightness, colour). In addition, I want to control other number-based items for example an effect intensity for my animations. Since it’s not directly related to a light bulb, I tried several other Google Assistant classes, without success. Which one is intended to be use for other number-based items?
I also have some contacts (e.g. door open/close), which are annotated with google assistant class “Door”. My goal is to ask the google assistant whether to door is closed or not. Unfortunately, the door contact isn’t visible in the Google Home app. Are contacts supported at all?
Thanks for your help!
