Does anybody have used the guillotine extension with the Gnome Desktop :
https://gitlab.com/ente76/guillotine/
I am trying to use this extension to control a switch (that turns my printer on or off from my Linux desktop).
I wrote the following configuration:
    "settings": {
        "loglevel": "warning"
    "menu": [
            "type": "switch",
            "title": "Imprimante HP",
            "start": "curl -X POST --header \"Content-Type: text/plain\" --header \"Accept: application/json\" -d \"ON\" \"http://192.168.1.51:8080/rest/items/ZWaveNode019ZMNHYDSmartPlug_Switch\"",
            "stop": "curl -X POST --header \"Content-Type: text/plain\" --header \"Accept: application/json\" -d \"OFF\" \"http://192.168.1.51:8080/rest/items/ZWaveNode019ZMNHYDSmartPlug_Switch\"",
            "check": "curl -H POST --header \"Content-Type: text/plain\" \"http://192.168.1.51:8080/rest/items/ZWaveNode019ZMNHYDSmartPlug_Switch\" | jq .state | grep ON",
            "icon": "~/.local/share/icons/hp1212.png",
            "interval_s": 2
            "type": "separator"
            "type": "submenu",
            "title": "Guillotine",
            "icon": "guillotine-symbolic",
            "items": [
                    "type": "command",
                    "title": "Configuration",
                    "command": "code .config/guillotine.json",
                    "icon": "preferences-other-symbolic",
                    "killOnDisable": false
                    "type": "command",
                    "title": "Log",
                    "command": "gnome-terminal -e 'journalctl -f GNOME_SHELL_EXTENSION_UUID=guillotine@fopdoodle.net'",
                    "instancing": "singleInstance",
                    "icon": "emblem-documents-symbolic",
                    "type": "command",
                    "title": "Log Gnome Shell",
                    "command": "gnome-terminal -e 'journalctl -f _COMM=gnome-shell' ",
I successfully switch on my printer with the guillotine menu. But I am unable to switch it off. The check command seems not to work either (in the menu the switch appears to be off although it is on).
I tested these commands with the bash shell without any problem, including the returning code for the check.
Any suggestion to make it to work ? Or Is there another solution similar to guillotine that works fine with Gnome ? (version 45)
