Hi every one, this is my first entry.
I’m pretty new to this openhab world.
can I control a philips hue’s light intensity with an item.
Number dim_test_number “Test number” {channel = “ihc: controller: elko: dim_test_number”}
really just follow the number from ihc item, the value goes from 1 - 100%
it is really a dimmer type item, i just treid to use it as a number.
Dimmer dim_test_number “Test dimmer” { channel=“ihc:controller:elko:dim_test_dimmer” }
and i just want the philis hue to follow the value of the dimmer in the ihc installation.
Okay, so you have a channel for your hue device? Add that to your Dimmer Item as well, but with a follow profile. Whatever updates are made to the Dimmer Item, will get sent as commands to the hue.
