I’m running openHAB 4.0.3 on a Raspberry Pi 4 Model B and would like to use the “X10 Controller Binding [3.3.0.0;4.0.0.0)” to communicate with a CM15A.
I’ve installed Mochad and am able to control some lamp modules using on/off/dim commands, with both RF and PL commands from a command line using Putty.
I would appreciate instructions on how to create the bridge, things and items from within OpenHAB 4. When I try to add a thing for the X10 binding, I get the screen shown at the end, but there’s nothing to click on.
\var\lib\openhab\jsondb contains the json definitions, but I’m not knowledgeable enough to create the definitions from scratch, and I’d rather create everything from within OpenHAB if possible.
I’ve tried contacting the author, but no reply. The name of the binding implies it should work with openHAB4, but the examples he provides look to be OH2 vintage, e.g.
I found recently that OH 4.0 UI does not show thing types if their id do not match addon name. Even if my addons were installed properly UI didn’t list thing types provided by them cause feature was named openhab-binding-bacnet but thing types/binding used co7io-bacnet identifier.
Thanks, Łukasz, but I think that’s not the problem here.
It’s a Community Marketplace binding, and the binding’s documentation implies that the thing and bridge must be defined textually (they won’t be discovered) and I don’t know how to do that in OH4.
There is syntax error in items file, it could be that it simply miss a new line at the end or have a wrong starting character (BOM for utf8 encoded files).
With regard to AbstractBridgeHandler log entry try commenting out / removing thing definitions and adding them back one by one and see which one triggers that message.
The “Bridge is not set” will require repairing the binding, I think. Not sure if I’m capable, but I’ll look into it. The message occurs when an X10 event takes place that is not initiated from OpenHAB even though the items that generate the error are defined inside OpenHAB (e.g. E1).
Or maybe, the OpenHAB name, e.g. TestDimmer needs to match the X10 “name” (E1)? <Edit: Nope. Just tried creating thing and item, both named “E7”. Same warnings.>
