I want to store a boolean test in a local variable in order to reuse it in different parts of the rule.
And I want to display in the log the result of a boolean test.
val check_pH = (neMB_pHvalue.state as DecimalType) > 8.5 || (neMB_pHvalue.state as DecimalType) < 6
logInfo("pH-test1",check_pH)
I got the following error message:
2022-07-22 10:22:43.776 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'poolSchedule-8' failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.actions.Log.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null in poolSchedule
How can I achieve this?
thanks
