Convert datetime string to valid DateTime Item OR to unix time
Hello -
Need some help or pointers to achieve the following.:
I have a string item that represents a date and time in the following format (UTC) → 201902231400. Now, I need to be able to display it in Habpanel as hh:mm (local time). To the best of my awareness, I have to either transform the string to a valid datetime object or to unix time to be able to use the angularjs date filters such as: {{ date_expression | date : format : timezone}}.
How would I do this?
Thanks,
Baobab
I moved this to the Habpanel topic as what you are all in seems to be about that.
