I read the string form a CO2 sensor (T6613) device by the serial binding. I have added -Dfile.encoding=ISO-8859-1 in Java args so the read and write of 8bit characters to the /dev/ttyS0 work ok.
I have an item
String RS_CO2 “RS_CO2 [%s]” { serial="/dev/ttyS0@19200" }
In my rule I have
rule "CO2 rs2232 wait for device"
Item RS_CO2 changed
var rsstring = RS_CO2.state.toString // The string looks like this "\u00FF\u00FA\u0002\u0002\u008A" . The last 2 bytes hold the value
var check = rsstring.substring(1,2) // Reads byte FA to test the answer is right
var valuestring = rsstring.substring(3,5) // Reads the value string from the string
if (check == "\u00FA") // right measure
var value = ????????????(valuestring)
postUpdate(CO2, value)
I have tried many conversions, but they all take a hexstring as a starting point, not a binary hex string.
Can anyone give me a hint on this issue and replace the ??? by a function. This can’t be to difficult?
Thank you for your help, but the answer is somewhere hidden in all the discussions. But you gave me a new insight with your answer and I now have it done. Far to complex and waiting for a simple solutions, but it is working.
Item RS_CO2 changed
var check = rsstring.substring(1,2) // check value
var valuestring = rsstring.substring(3,4) // high
var valuestring2 = rsstring.substring(4,5) // low
var char [] array = rsstring.toCharArray()
val StringBuilder sb = new StringBuilder
array.forEach (b | sb.append(Integer::toHexString(b) + " ")) // readable string for debug
var char [] array2 = valuestring.toCharArray()
val StringBuilder sb2 = new StringBuilder
array2.forEach (b | sb2.append(Integer::toHexString(b))) // high
var char [] array3 = valuestring2.toCharArray()
val StringBuilder sb3 = new StringBuilder
array3.forEach (b | sb3.append(Integer::toHexString(b))) // low
if (check == "\u00fa") // check right string
var value = Integer::parseInt(String::format("%s",sb2), 16) //high
var value2 = Integer::parseInt(String::format("%s",sb3), 16) // low
var value3 = value * 256 + value2
postUpdate(AD_CO2, value3)
logInfo("CO2 rs 232", "String CO2 =" + sb + "value =" + value3 )
