noxx
(Ralf B.)
March 12, 2018, 10:47am
#25
@vzorglub
my computer was corrupt, sorry for my late answer.
i try your latest code, and now i get only this:
1520846028
JSON:
{"data":[{"active":true,"analysed":1,"done":16.833320500932302,"job":"E3DV6_Chain_Closed_Full_V4.","jobid":22,"linesSend":50285,"name":"ANET","ofLayer":68,"online":1,"pauseState":0,"paused":false,"printTime":18913.532202940485,"printedTimeComp":4334.7602734694547,"slug":"ANET2","start":1520846028,"totalLines":298723}]}
LOG
2018-03-12 11:47:00.113 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'rep update': Could not cast 1520846028 to org.eclipse.smarthome.core.library.types.DecimalType; line 44, column 34, length 29
With your old function:
(function(i) {
var date = new Date(parseInt(i) * 1000);
return date.toISOString();
})(input)
i get
2018-03-12T09:13:48.000Z
vzorglub
(Vincent Regaud)
March 12, 2018, 11:09am
#26
It seems the the JS transform doesnβt like parsing a string integer into a float so lets try to change it into a float in the rule
try:
rule "rep update"
Item RepStart received update or
Item RepEnd received update
var startTime = RepStart.state as Number
var endTime = RepEnd.state as Number
endTime = startTime + endTime
startTime = startTime + 0.1
RepStartNumber.postUpdate(startTime.toString)
RepEndNumber.postUpdate(endTime.toString)
vzorglub
(Vincent Regaud)
March 12, 2018, 11:41am
#27
I have done a bit of testing.
My previous javascript was untested. I was full of bugs, surprise surprise.
Try this: (Replace the whole script)
AND remove the line I added in the rule previously although it shouldnβt matter.
(function(i) {
var value = parseFloat(i)
var date = new Date(parseInt(value) * 1000);
var weekDay = "";
var day = "";
var month = "";
var year = "";
var hours = "";
var minutes = "";
var seconds = "";
//Sun, 03/03/2018 17:55:16
switch (date.getDay()) {
case 0:
weekDay = "Sun";
break;
case 1:
weekDay = "Mon";
break;
case 2:
weekDay = "Tue";
break;
case 3:
weekDay = "Wed";
break;
case 4:
weekDay = "Thu";
break;
case 5:
weekDay = "Fri";
break;
case 6:
weekDay = "Sat";
break;
if (date.getDate() < 10) {
day = '0' + date.getDate().toString();
} else {
day = date.getDate().toString();
if (date.getMonth() < 10) {
month = '0' + date.getMonth().toString();
} else {
month = date.getMonth().toString();
year = (date.getFullYear() - 2000).toString();
if (date.getHours() < 10) {
hours = '0' + date.getHours().toString();
} else {
hours = date.getHours().toString();
if (date.getMinutes() < 10) {
minutes = '0' + date.getMinutes().toString();
} else {
minutes = date.getMinutes().toString();
if (date.getSeconds() < 10) {
seconds = '0' + date.getSeconds().toString();
} else {
seconds = date.getSeconds().toString();
var result = weekDay + ', ' + day + '/' + month + '/' + year + ' ' + hours + ':' + minutes + ':' + seconds;
return result;
})(input)
vzorglub
(Vincent Regaud)
March 12, 2018, 12:13pm
#29
Do you get the correct values for start time and end time?
Happy to help
noxx
(Ralf B.)
March 12, 2018, 1:48pm
#30
noxx:
1520846028
99% are correct
i seems the value for the month isnt correct
12/02/18
but, today is 12/03/18
the rest works good, thx
vzorglub
(Vincent Regaud)
March 12, 2018, 1:53pm
#31
The month index starts at 0!
months 0 to 11
Just add one to the getMonth()
if ((date.getMonth() + 1) < 10) {
month = '0' + (date.getMonth() + 1).toString();
} else {
month = (date.getMonth() + 1).toString();
