hello,
how can i convert a timestamp (e.g. 1520073863) to a readable format?
i read my item via JSON.
thx for help.
hello,
thx for help.
Can you post your item definition?
What do you want do do?
Or take a look at this:
DateTimeType is explained in the mid…
this was my item
Number RepStart "Start [%s]" {http="<[http://192.168.1.227:3344/printer/list:10000:JSONPATH($.data[0].start)]"}
this was the complete info of my JSON File
{"data":[{"active":true,"analysed":1,"done":0.13900380605659440,"job":"1_Z_Motor_Mount_Left.","jobid":9,"linesSend":294,"name":"ANET","ofLayer":250,"online":1,"pauseState":0,"paused":false,"printTime":22410.677829925866,"printedTimeComp":507.33782463806983,"slug":"ANET2","start":1520073863,"totalLines":211505}]}
to add the start-value works.
in this case 1520073863 is a timestamp for Saturday, 03-Mar-18 10:44:23 UTC
at first, i want in my BasicUI “Saturday, 03-Mar-18 10:44:23 UTC” and not
1520073863. so i think, i must confert the timestamp of my JSON file to a real date-time-value. but how?
https://docs.openhab.org/addons/bindings/ntp/readme.html
Number RepStart "Start [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" {http=...
Number RepStart “Start [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]” {http=…
or
DateTime RepStart “Start [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]” {http=…
dont work ![]()
2018-03-03 18:01:13.616 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value '1520073863' of item RepStart with format '%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM': {}
Create a TimeFormat.js file in your transform folder
with the following content
(function(i) {
var date = new Date(i * 1000);
return date.toISOString();
})(input)
and your item
DateTime RepStart "[JS(TimeFormat.js):%s]" {http="<[http://192.168.1.227:3344/printer/list:10000:JSONPATH($.data[0].start)]"}
Good luck
i get only a “-”
possible that this was a problem?
2018-03-03 20:50:52.849 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - transformation throws exception [transformation=org.eclipse.smarthome.transform.javascript.internal.JavaScriptTransformationService@1a5428c, value=-]
org.eclipse.smarthome.core.transform.TransformationException: An error occurred while executing script.
at org.eclipse.smarthome.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:84) [245:org.eclipse.smarthome.transform.javascript:0.10.0.b1]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.transform(ItemUIRegistryImpl.java:462) [155:org.eclipse.smarthome.ui:0.10.0.b1]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:386) [155:org.eclipse.smarthome.ui:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:118) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.TextRenderer.renderWidget(TextRenderer.java:42) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:172) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:137) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:158) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:100) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:179) [196:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
Caused by: javax.script.ScriptException: RangeError: Invalid Date in <eval> at line number 3
at jdk.nashorn.api.scripting.NashornScriptEngine.throwAsScriptException(NashornScriptEngine.java:470) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:454) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:406) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:402) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.eval(NashornScriptEngine.java:150) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:249) ~[?:?]
at org.eclipse.smarthome.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:82) ~[?:?]
... 35 more
Caused by: jdk.nashorn.internal.runtime.ECMAException: RangeError: Invalid Date
at jdk.nashorn.internal.runtime.ECMAErrors.error(ECMAErrors.java:57) ~[?:?]
at jdk.nashorn.internal.runtime.ECMAErrors.rangeError(ECMAErrors.java:266) ~[?:?]
at jdk.nashorn.internal.runtime.ECMAErrors.rangeError(ECMAErrors.java:238) ~[?:?]
at jdk.nashorn.internal.runtime.ECMAErrors.rangeError(ECMAErrors.java:225) ~[?:?]
at jdk.nashorn.internal.objects.NativeDate.toISOStringImpl(NativeDate.java:1043) ~[?:?]
at jdk.nashorn.internal.objects.NativeDate.toISOString(NativeDate.java:845) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$1219826$13A$\^eval\_.L:1(<eval>:3) ~[?:?]
at jdk.nashorn.internal.scripts.Script$1219825$\^eval\_.:program(<eval>:1) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:637) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:494) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:393) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:449) ~[?:?]
... 35 more
I wrote that JS function on top of my head
Difficult to debug in openHAB
Try:
(function(i) {
var date = new Date(parseInt(i) * 1000);
})(input)
The javascript transform only passes strings so parse i into an integer
thx, works with a item as string
is it possible to calculate with this?
e.g.
item Start = 1520099716
item Duration = 12345
→ item End = Start + Duration (as readable Time)
thx for help
regard
You will need 4 items:
String RepStart {JSON} // your item definition
String RepEnd {JSON} // your item definition
Number RepStartNumber "[JS(TimeFormat.js):%s]"
Number RepEndNumber "[JS(TimeFormat.js):%s]"
and a rule:
rule "rep update"
Item RepStart received update or
Item RepEnd received update
var startTime = Integer::parseInt(RepStart.state.toString())
var endTime = Integer::parseInt(RepEnd.state.toString())
endTime = startTime + endTime
RepStartNumber.postUpdate(startTime)
RepEndNumber.postUpdate(endTime)
Good luck
thx, will try this. and my last question (sorry).
can i format the output?
e.g.
from 2018-03-03T17:55:16.000Z
to
Sun, 03/03/2018 17:55:16
really my last question ![]()
have a problem
endTime isnt a integer. example: 1077.9310463460163
can i convert this to 1077 or 1078?
regard
Try that instead:
rule "rep update"
var startTime = RepStart.state as Number
var endTime = RepEnd.state as Number
RepStartNumber.postUpdate(startTime.toString)
RepEndNumber.postUpdate(endTime.toString)
thx
i get this here
Rule 'rep update': Could not cast 1520184351 to java.lang.Number; line 44, column 21, length 24
this are from my items:
2018-03-04 18:32:03.300 [vent.ItemStateChangedEvent] - RepStart changed from NULL to 1520184351
RepEnd changed from 706.4367411783377 to 717.2421195238306
You didn’t eliminate the typo
Please consider to edit the posting, this is more helpful, when someone finds this thread and tries the code without reading all postings ![]()
Got it!!!
Didn’t think of going back to change the original post
