Converting a Hex String to a Number using parseInt
I’m trying to convert the hex number output of a battery pack to a number item using parseInt inside a rule. So far my attempts have been giving me persistent errors.
Heres the rule:
rule "Battery Level"
when Time cron "0/15 * * * * ?" //run every 15 seconds
   var string = executeCommandLine("i2cget -y 1 0x62 0x4 b",10000)
   logInfo("Hex",string)
   var int value = Integer::parseInt(string)
   logInfo("Test",value)
Log Output:
2020-10-17 19:22:15.067 [INFO ] [g.eclipse.smarthome.model.script.Hex] - 0x61
2020-10-17 19:22:15.072 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule ‘Battery Level’: For input string: “0x61”
I’ve also tried giving parseInt a string directly parseInt(‘0x61’) however it still results in the above error, same with parseInt(‘0x61’, 16)
Any help would be appreciated I’ve been stuck on this for hours now :sleepy:
var int value = Integer::parseInt(string, 16)
Still gives me the same error sadly
2020-10-17 19:44:00.073 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule ‘Battery Level’: For input string: “0x61”
Put this at the top of rule file
import java.lang.*
and change it to
var value = Integer::parseInt(string, 16)
Gives me the following output:
2020-10-17 20:28:25.282 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘battery.rules’, using it anyway:
The use of wildcard imports is deprecated.
2020-10-17 20:28:25.371 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘battery.rules’
2020-10-17 20:28:30.224 [INFO ] [g.eclipse.smarthome.model.script.Hex] - 0x60
2020-10-17 20:28:30.230 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule ‘Battery Level’: For input string: “0x60”
Why is it not working I going bald, I have tried also
  //convert hex_code to Number type
   var MyNumber = Integer.parseInt(hex_code, 16) as Number
  //use the following for large_hex_code
  var MyNumber1 = Long.parseLong(hex_code, 16) as Number
   // coverting hex_code into DecimalType
  var DecimalType parsedResult = DecimalType.valueOf(Long.parseLong(hex_code, 16).toString);
   val itemvalue = new java.math.BigDecimal(Integer::parseInt(hex_code, 16))
I guess I don’t know or its not working or is broken.
Oh well try another approach
Install JS Transformation Pattern
Create File in transformation folder
HEXtoDEC.JS
(function(i) {
  if (i == 'NULL') { return i; }
  if ((i == '-') || (i == 'UNDEF')) { return 'Undefined'; }
  return (parseInt(i,16));
})(input)
Then use a transform in your rule
   var hex_code = executeCommandLine("i2cget -y 1 0x62 0x4 b",10000)
   var value = transform("JS", "HEXtoDEC.js", hex_code)
   logInfo("Hex",hex_code)
It’s working, cheers!!
The only little niggly issue remaining is that the value variable still appears to be a string so I’m unable to perform any mathematical operations on it.
I’ve tried using var int value and var Number value but no luck.
Transformations always return strings - but now it’s a “decimal” string and you can parse that.
Ok so I think it was my item definition causing issues, the rule now returns a NumberItem.
Here’s the rule:
when Time cron "0/30 * * * * ?" //run every 30 seconds
    var value = transform("JS", "HEXtoDEC.JS", hex_code)
    Battery.postUpdate(value)
    logInfo("Battery", Battery.toString)
Item:
Number Battery "Battery Percentage [%s %%]" <batterylevel>
Thanks for the help i’ll mark this as solved :upside_down_face:
