Can someone advise what are the correct port settings for the serial ports in Openhab v5 on Raspberry Pi. I have tried tcp://ipaddress:4999 or 5000, and socket://ipaddress:4999 or 5000, as suggested in some search results, but these do not appear to work.
I’m a little confused… Are you using the GlobalCache binding? Because it knows what port numbers to open to talk to the serial ports (4999 for serial port 1 and 5000 for port 2, as you already stated). All you do is configure the parameters of the serial ports using the GC-100-12, and then send your serial commands to the appropriate thing channel.
I have the GlobalCache setup with correct parameters, and the GlobalCache binding setup. I am connecting a Sony projector to serial 1 and in that binding it requires the configuration for the serial port to use, and that is where I have tried the tcp://ipaddress:4999 where ipaddress is the ip of the GlobalCache.
I’m so confused. This is what I have for my GC-100-06 thing.
version: 1
things:
globalcache:gc100_06:mediaRoomGc100:
label: GlobalCache MediaRoom GC-100-06
ipAddress: 192.168.40.81
mapFilename: globalcache-codes.map
enableTwoWay1: false
eomDelimiter1: '%0A'
macAddress: 000C1E00F0E9
channels:
sl-m1#c1:
type: channel-type-sl
label: Connector 1 (mapped)
description: Mapped commands to serial port
sl-m1#c1-direct:
type: channel-type-sl-direct
label: Connector 1 (direct)
description: Direct commands to serial port
sl-m1#c1-receive:
type: channel-type-sl-receive
label: Connector 1 (receive)
description: Data received on serial port
ir-m2#c1:
type: channel-type-ir
label: Connector 1
description: Infrared emitter on connector 1. Connector 1 is the connector closest to the power plug.
ir-m2#c2:
label: Connector 2
description: Infrared emitter on connector 2.
ir-m2#c3:
label: Connector 3
description: Infrared emitter/blaster on connector 3.
And then I just have an item mapped to the serial 1 channel (sl-m1#c1) and I use the map file to convert the command I send to the serial codes. You also could use the “direct” channel if you want to send the codes in the command.
