Corrupt installation after updating from 3.1 (M5) to 3.2.M4
I working on openhabian and used openhabian-config to update from 3.1 (M5) to 3.2.M4 and during the installation it fails. When checking the console there appears to the following issue.
After this operation, 20.8 MB of additional disk space will be used.
Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf base-files armhf 10.3+rpi1+deb10u10
  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf libgssapi-krb5-2 armhf 1.17-3+deb10u2
Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf libkrb5-3 armhf 1.17-3+deb10u2
Err:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf libkrb5support0 armhf 1.17-3+deb10u2
Err:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf libk5crypto3 armhf 1.17-3+deb10u2
Err:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf libdns1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u5
Get:7 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab all 3.1.0-1 [98.7 MB]
Get:8 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab-addons all 3.1.0-1 [242 MB]
Fetched 340 MB in 1min 2s (5,474 kB/s)
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/b/base-files/base-files_10.3+rpi1+deb10u10_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/k/krb5/libgssapi-krb5-2_1.17-3+deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/k/krb5/libkrb5-3_1.17-3+deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/k/krb5/libkrb5support0_1.17-3+deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/k/krb5/libk5crypto3_1.17-3+deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/b/bind9/libdns1104_9.11.5.P4+dfsg-5.1+deb10u5_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
A ping and curl to the above addresses work (eg 2a00:1098:0:80:1000:75:0:3).
when trying to do a “apt-get update” it again runs into an issue
enhabian@openHABianDevice:/etc/apt/sources.list.d $ sudo apt-get update
[sudo] password for openhabian:
Get:1 http://davesteele.github.io/comitup/repo comitup InRelease [3,936 B]
Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Get:4 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Err:1 http://davesteele.github.io/comitup/repo comitup InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0959C4A3DCF89FBF
Hit:5 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Reading package lists... Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://davesteele.github.io/comitup/repo comitup InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0959C4A3DCF89FBF
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
which reveals there seems to bei an issue trying to access the openhab-linuxpkg on jfrog because of missing the key.
I checked similar forum threads but with all the hints didn’t help in my case
TIA
Stefan
You also tried this
wget -O -  https://davesteele.github.io/key-366150CE.pub.txt | sudo apt-key add  -
to add the missing pub key ?
Yep, that is the one I found in the other thread and it didn’t help unfortunately.
That’s the way the supplier of the repository documented how to do it at Comitup | Bootstrap WiFi networking using the WiFi connection . If that does not work I would assume that the key was changed and not yet published on their page ..?
You also can check if an other method on page https://davesteele.github.io/key-366150CE.pub.txt leads to an other result ( which I doubt ).
I have the same exact issue, did you find a way to resolve it and upgrade?
