i’ve been running openHAB 3 for a while now with this setup (zram enabled):
## Release = Raspbian GNU/Linux 10 (buster)
## Kernel = Linux 5.10.103-v7l+
## Platform = Raspberry Pi 4 Model B Rev 1.1
## Uptime = 0 day(s). 0:18:17
## CPU Usage = 0.75% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.52, 5m: 0.37, 15m: 0.30
## Memory = Free: 2.46GB (65%), Used: 1.32GB (35%), Total: 3.79GB
## Swap = Free: 0.53GB (100%), Used: 0.00GB (0%), Total: 0.53GB
## Root = Free: 2.63GB (39%), Used: 4.04GB (61%), Total: 7.00GB
## Updates = 132 apt updates available.
## Sessions = 1 session(s)
## Processes = 138 running processes of 32768 maximum processes
_ _ _ ____ _
___ ___ ___ ___ | | | | / \ | __ ) (_) ____ ___
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \ | | / _ \ / _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )| || (_) || | | |
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/ |_| \__|_||_| | |
|_| openHAB 3.3.0 - Release Build
on monday i had to shutdown the raspberry (sudo shutdown -h now) and after reboot my item states weren’t restored to their previous state.
after another reboot (sudo reboot) the problem was the same. yesterday i noticed that some rules aren’t working like they are supposed to (and as they did before shutdown on monday) i checked the logs and there are many entries with the same error (different items):
[ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/WS_UV.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/WS_UV.rrd] is not a RRD4J RRD file
i searched the community for help and tried to delete the file (actually i deleted the rrd file for all items with this error):
sudo systemctl stop openhab.service
sudo rm /var/lib/openhab/persistence/rrd4j/WS_UV.rrd
sudo systemctl start openhab.service
but the error reappears again. also tried to reboot. same effect. and i still lose items states on start or reboot. from what i experienced this might have to do with zram, but i’m not sure how to verify this.
best regards
Peter
