Changing this to not SOLVED, since it happened again to me
I had a few minutes to debug this further. It looks like, at least, the wemo mini switch is changing the ports that it communicates on. The binding may not be rediscovering and using the new port.
Here is a tcpdump summary of openhab trying to set the switch:
22:31:33.736114 IP alarmpi.33050 > wemominikeg.local.49154: Flags [S], seq 218943257, win 29200, options [mss 1460,sackOK,TS val 373431294 ecr 0,nop,wscale 7], length 0
22:31:33.737780 IP wemominikeg.local.49154 > alarmpi.33050: Flags [R.], seq 0, ack 218943258, win 0, length 0
It is trying to communicate to the switch over port 49154, I assume from initial discovery. However the device is no longer listening on that port. I didn’t have time to do a full debug of this so downloaded
https://github.com/iancmcc/ouimeaux and let it do the discovery and found that it is now using port 49157
(ouimeaux-env) root@alarmpi:~/ouimeaux/ouimeaux-env# wemo -d status
DEBUG:ouimeaux.discovery:Binding datagram server to 192.168.1.43:54321
INFO:ouimeaux.environment:Discovering devices
DEBUG:ouimeaux.discovery:Broadcasting M-SEARCH to 239.255.255.250:1900
DEBUG:ouimeaux.discovery:Received a response from 192.168.1.208:55271
DEBUG:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.208:49157
DEBUG:urllib3.connectionpool:http://192.168.1.208:49157 "GET /setup.xml HTTP/1.1" 200 4484
DEBUG:urllib3.connectionpool:http://192.168.1.208:49157 "GET /setupservice.xml HTTP/1.1" 200 4091
DEBUG:urllib3.connectionpool:http://192.168.1.208:49157 "GET /timesyncservice.xml HTTP/1.1" 200 1630
I wrote a quick shell script to just throw the SOAP packet at the mini switch to turn the switch off/on port 49157 and it worked fine. I can control the switch. So I guess the wemo binding does not do periodic re-discovery? Also 49157 was not usually in the list of wemo ports that I had previously. I’m wondering if the wemo mini is the first one to use it, and also change its ports periodically.
root@alarmpi:~/root# ./wemotest3.sh 192.168.1.208 0
try port 192.168.1.208:49152
nc: connect to 192.168.1.208 port 49152 (tcp) failed: Connection refused
try port 192.168.1.208:49153
Connection to 192.168.1.208 49153 port [tcp/*] succeeded!
try port 192.168.1.208:49154
nc: connect to 192.168.1.208 port 49154 (tcp) failed: Connection refused
try port 192.168.1.208:49155
Connection to 192.168.1.208 49155 port [tcp/*] succeeded!
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<s:Fault>
<faultcode>s:Client</faultcode>
<faultstring>UPnPError</faultstring>
try port 192.168.1.208:49156
Connection to 192.168.1.208 49156 port [tcp/*] succeeded!
<detail>
<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">
<errorCode>-1</errorCode>
<errorDescription>Invalid Action</errorDescription>
</UPnPError>
</s:Envelope>
try port 1 92.168.1.208:49157
Connection to 192.168.1.208 49157 port [tcp/*] succeeded!
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
<u:GetBinaryStateResponse xmlns:u="urn:Belkin:service:basicevent:1">
<BinaryState>0</BinaryState>
</u:GetBinaryStateResponse>
</s:Body> </s:Envelope>
<u:SetBinaryStateResponse xmlns:u="urn:Belkin:service:basicevent:1">
<BinaryState>1</BinaryState>
<CountdownEndTime>0</CountdownEndTime>
<deviceCurrentTime>1540177142</deviceCurrentTime>
</u:SetBinaryStateResponse>
For now, I can at least control these type of wemo devices by just running a shell script which does the SOAP request to turn on/off. If anyone needs the scrip.
#!/bin/sh
ip=$1
state=$2
for port in 49152 49153 49154 49155 49156 49157
do
echo try port $ip:$port
echo " "
nc -zv $ip $port
curl -m 2 -X POST -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" -H 'Accept:' --data "<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><u:GetBinaryState xmlns:u=\"urn:Belkin:service:basicevent:1\"></u:GetBinaryState></s:Body></s:Envelope>" -s http://$ip:$port/upnp/control/basicevent1
echo
curl -m 2 -X POST -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data "<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><u:SetBinaryState xmlns:u=\"urn:Belkin:service:basicevent:1\"><BinaryState>$state</BinaryState></u:SetBinaryState></s:Body></s:Envelope>" -s http://$ip:$port/upnp/control/basicevent1
echo
curl -m 2 -X POST -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" --data "<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><u:GetBinaryState xmlns:u=\"urn:Belkin:service:basicevent:1\"></u:GetBinaryState></s:Body></s:Envelope>" -s http://$ip:$port/upnp/control/basicevent1
done
Looking at the code, it appears this binding only does discovery at activation. For cases where the wemo device may decide to change its port in the Location discovery response, the device will not be accessible. I believe my device changed its port when I restarted my wifi on the router – not sure if this is a wemo mini thing or just the latest firmeware.
However when I restart, or (stop-start) the binding, the probem does not resolve. I see the following logs:
2018-10-22 01:07:34.066 [DEBUG] [nding.wemo.internal.discovery.WemoDiscoveryService] - Starting UPnP RootDevice search...
2018-10-22 01:07:34.144 [DEBUG] [g.wemo.internal.discovery.WemoDiscoveryParticipant] - Discovered a WeMo Socket thing with UDN 'Socket-1_0-221816K0103611'
2018-10-22 01:07:34.148 [DEBUG] [g.wemo.internal.discovery.WemoDiscoveryParticipant] - Created a DiscoveryResult for device 'Kegerator' with UDN 'Socket-1_0-221816K0103611'
2018-10-22 01:07:34.260 [DEBUG] [smarthome.binding.wemo.internal.WemoHandlerFactory] - Trying to create a handler for ThingType 'wemo:socket
2018-10-22 01:07:34.264 [DEBUG] [smarthome.binding.wemo.internal.WemoHandlerFactory] - Creating a WemoHandler for thing 'wemo:socket:Socket-1_0-221816K0103611' with UDN 'Socket-1_0-221816K0103611'
2018-10-22 01:07:34.268 [DEBUG] [eclipse.smarthome.binding.wemo.handler.WemoHandler] - Creating a WemoHandler for thing 'wemo:socket:Socket-1_0-221816K0103611'
2018-10-22 01:07:34.291 [DEBUG] [eclipse.smarthome.binding.wemo.handler.WemoHandler] - Initializing WemoHandler for UDN 'Socket-1_0-221816K0103611'
2018-10-22 01:07:34.295 [DEBUG] [eclipse.smarthome.binding.wemo.handler.WemoHandler] - Checking WeMo GENA subscription for 'org.eclipse.smarthome.binding.wemo.handler.WemoHandler@3eb115'
2018-10-22 01:07:34.299 [DEBUG] [eclipse.smarthome.binding.wemo.handler.WemoHandler] - Setting up GENA subscription Socket-1_0-221816K0103611: Subscribing to service basicevent1...
2018-10-22 01:07:34.313 [DEBUG] [smarthome.binding.wemo.internal.WemoHandlerFactory] - Trying to create a handler for ThingType 'wemo:socket
2018-10-22 01:07:34.326 [DEBUG] [.smarthome.binding.wemo.internal.http.WemoHttpCall] - Could not make HTTP call to WeMo
Unfortunately the code does not print out WHAT the discovery result actually is, but I know that the switch is sending back a valid discovery by doing one outside of openhab. It is returning:
HTTP/1.1 200 OK
CACHE-CONTROL: max-age=86400
DATE: Mon, 22 Oct 2018 05:22:33 GMT
EXT:
OPT: "http://schemas.upnp.org/upnp/1/0/"; ns=01
01-NLS: e421321a-1dd1-11b2-ae9e-d396178ab2d2
SERVER: Unspecified, UPnP/1.0, Unspecified
X-User-Agent: redsonic
ST: upnp:rootdevice
USN: uuid:Socket-1_0-221816K0103611::upnp:rootdevice
And confirmed by going to that address and issues the normal on/off commands (which works fine).
So in summary, wemo can change the port for SOAP calls, the openhab wemo binding never does rediscovery to pick it up, and trying to restart or stop/start the binding does not fix the problem.
Any idea would be appreciated.
Thanks.
