Your regex seems not to be the same as as posted from @rlkoshak.
I think as your regex is embedded into a string you have to properly escape the backslash.
https://docs.openhab.org/addons/transformations/regex/readme.html#differences-to-plain-regex
- As it seems that you want to match a multiline string you need something like
"REGEX(s/.+\\s.+(.*)/$1/g)"
Explain in detail in this post.
I did not test it but it should be something like
Number Power { mqtt="<[mosquitto:Electricity/EL/Energy/Import/kWh:state:REGEX((\\d*.\\d*).*)]" }
DateTime Power_Time { mqtt="<[mosquitto:Electricity/EL/Energy/Import/kWh:state:REGEX(s/.*\\s(.*)/$1/g)]" }
