I’m currently trying to add my Atlantic Serenis towel dryer to OpenHab in order to be able to launch the boost mode automatically when activating the “Shower mode” of my installation.
I successfully added the Somfy Tahoma binding using ha110-1.overkiz.com and my identifiers, however, my thing isn’t detected (The is a lot of sensor I doesn’t have that are, however, detected, like a presence sensor). Looking at the documentation I fear it’s not implemented.
There is a Thing that could match, but you can only send strings (off, eco, comfort, frostprotection), you can’t trigger boost mode, dry mode or set a custom temperature.
Have someone succeeded in implementing the Somfy tahoma binding for Atlantic electric heater/towel dryer ?
Thanks in advance for any answer.
