Hey
I am using Openhab in Version 4.1.1 with a full running system (no errors at all). After I install a new Binding of Shelly (Shelly - Bindings | openHAB) the error log is running full of messages based on errors on Jeelink (Jeelink - Bindings | openHAB) It starts with:
2024-01-16 07:57:10.748 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager gestartet und erreichbar unter http(s)://192.168.1.51:8080/shelly/manager
2024-01-16 07:57:23.080 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'bewegungsmelder-1' failed: An error occurred during the script execution: Cannot invoke "org.openhab.core.model.rule.scoping.RulesClassCache.get(Object)" because "cache" is null in bewegungsmelder
2024-01-16 07:57:23.082 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'helligkeitssteuerung-1' failed: An error occurred during the script execution: Cannot invoke "org.openhab.core.model.rule.scoping.RulesClassCache.get(Object)" because "cache" is null in helligkeitssteuerung
2024-01-16 07:57:25.157 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.jeelink.internal.lacrosse.LaCrosseTemperatureSensorHandler@18106352': Cannot invoke "org.openhab.core.thing.Bridge.getHandler()" because the return value of "org.openhab.binding.jeelink.internal.JeeLinkSensorHandler.getBridge()" is null
java.lang.NullPointerException: Cannot invoke "org.openhab.core.thing.Bridge.getHandler()" because the return value of "org.openhab.binding.jeelink.internal.JeeLinkSensorHandler.getBridge()" is null
at org.openhab.binding.jeelink.internal.JeeLinkSensorHandler.dispose(JeeLinkSensorHandler.java:86) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
After some repeats of the same message openhab restarts:
2024-01-16 07:57:29.441 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2024-01-16 07:57:29.800 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Stopped HABPanel
2024-01-16 07:57:38.481 [WARN ] [ore.internal.scheduler.SchedulerImpl] - Scheduled job '<unknown>' failed and stopped
java.lang.NullPointerException: Cannot invoke "org.openhab.core.model.rule.scoping.RulesClassCache.get(Object)" because "cache" is null
at org.openhab.core.model.rule.scoping.RulesClassFinder.forName(RulesClassFinder.java:43) ~[?:?]
at org.openhab.core.model.rule.scoping.RulesClassFinder.forName(RulesClassFinder.java:1) ~[?:?]
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:133) ~[?:?]
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getMethod(JavaReflectAccess.java:74) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1171) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1167) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1153) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1098) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:878) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1222) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1152) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1008) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:249) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:486) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:267) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:47) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:30) ~[?:?]
at jdk.proxy272.$Proxy384.apply(Unknown Source) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:189) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:88) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2024-01-16 07:57:43.193 [WARN ] [service.internal.HttpServiceDisabled] - Http service has already been stopped
2024-01-16 07:57:44.188 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.1.1 (build Release Build)
After openHab is back, the log is getting flodded on the following messages
2024-01-16 07:58:26.744 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler LaCrosseTemperatureSensorHandler tried updating the thing status although the handler was already disposed.
2024-01-16 07:58:26.745 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler LaCrosseTemperatureSensorHandler tried updating the thing status although the handler was already disposed.
2024-01-16 07:58:26.746 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler LaCrosseTemperatureSensorHandler tried updating the thing status although the handler was already disposed.
After I uninstall Shelly again and restart the service everything is fine again …
Does anybody know this issue and have a solution?
Best wishes
Thomas
