Crazy behaviour after rebooting Raspberry Pi
hi all,
hope someone can help me with the following problem.
when i reboot my raspberry pi and openhab is starting, it seems like every rule is triggered and errors flood my logfile.
here is my log right after a “sudo reboot”
2015-10-02 02:07:37.325 [INFO ] [penhab.io.rest.RESTApplication] - Stopped REST API
2015-10-02 02:07:41.373 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Stopped Classic UI
2015-10-02 02:08:21.391 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.7.1).
2015-10-02 02:08:27.064 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2015-10-02 02:08:27.280 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2015-10-02 02:08:27.304 [INFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2015-10-02 02:08:27.306 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2015-10-02 02:08:35.333 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'HA.sitemap'
2015-10-02 02:08:36.280 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'O.sitemap'
2015-10-02 02:08:36.454 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'myopenhab.persist'
2015-10-02 02:08:36.554 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2015-10-02 02:08:36.849 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'blink3xgruen.script'
2015-10-02 02:08:37.884 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2015-10-02 02:08:37.994 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'HA.items'
2015-10-02 02:08:43.484 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
2015-10-02 02:08:48.388 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rules.rules'
2015-10-02 02:08:56.224 [INFO ] [.myopenhab.internal.MyOHClient] - Connected to my.openHAB service (UUID = XXX, base URL = http://localhost:8080)
2015-10-02 02:08:57.342 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule 'Office - Helligkeit analysieren und Licht schalten': Cannot cast org.openhab.core.types.UnDefType to org.openhab.core.library.types.DecimalType
2015-10-02 02:08:57.908 [WARN ] [.o.c.p.e.PersistenceExtensions] - There is no queryable persistence service registered with the name 'rrd4j'
2015-10-02 02:08:57.913 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule 'Temperaturminimum und -maximum anzeigen': cannot invoke method public abstract org.openhab.core.types.State org.openhab.core.persistence.HistoricItem.getState() on null
2015-10-02 02:08:58.156 [WARN ] [.o.c.p.e.PersistenceExtensions] - There is no queryable persistence service registered with the name 'rrd4j'
2015-10-02 02:08:58.161 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule 'Luftfeuchtigkeit Minimum und Maximum anzeigen': cannot invoke method public abstract org.openhab.core.types.State org.openhab.core.persistence.HistoricItem.getState() on null
2015-10-02 02:08:58.457 [WARN ] [.o.c.p.e.PersistenceExtensions] - There is no queryable persistence service registered with the name 'rrd4j'
2015-10-02 02:08:58.463 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule 'GH Aussentemperaturminimum und -maximum anzeigen': cannot invoke method public abstract org.openhab.core.types.State org.openhab.core.persistence.HistoricItem.getState() on null
2015-10-02 02:08:58.940 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule 'Zuhause, schalte Licht':
2015-10-02 02:08:59.002 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule 'cooldown': Cannot cast org.openhab.core.types.UnDefType to org.openhab.core.library.types.DecimalType
2015-10-02 02:08:59.078 [INFO ] [.p.internal.PanasonicTVBinding] - TV registered 'viera' with IP '192.168.178.32'
2015-10-02 02:09:01.935 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Zuhause, schalte Licht'
    at org.openhab.model.script.lib.NumberExtensions.operator_lessThan(NumberExtensions.java:61) ~[na:na]
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0]
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0]
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0]
    at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0]
    at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
    at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
    at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source) ~[na:na]
    at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
    at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
    at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
    at sun.reflect.GeneratedMethodAccessor42.invoke(Unknown Source) ~[na:na]
    at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
    at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:636) ~[na:na]
    at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:327) ~[na:na]
    at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
    at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
    at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
    at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) ~[na:na]
2015-10-02 02:09:01.947 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Zuhause, schalte Licht'
2015-10-02 02:09:03.670 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'nachtlicht'
    at org.openhab.model.script.lib.NumberExtensions.operator_lessEqualsThan(NumberExtensions.java:69) ~[na:na]
2015-10-02 02:09:04.065 [INFO ] [rg.openhab.model.script.System] - B?roalarm: --> Motion detected!!!
2015-10-02 02:09:04.237 [INFO ] [org.openhab.model.script.DEBUG] - Gasupdate
2015-10-02 02:09:04.352 [INFO ] [rg.openhab.model.script.System] - Sound
2015-10-02 02:10:00.078 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Zuhause, schalte Licht
    at sun.reflect.GeneratedMethodAccessor47.invoke(Unknown Source) ~[na:na]
    at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
    at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
    at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
after all those errors everything seems to work fine again…
has anyone experienced something like this before and might be able to help?
i can post my rules, items and sitemap if that helps?
thank you!
stefan
It looks like a series of rules are firing on startup, before item state has been initialised or restored from persistence. You might need to add some logic in your rules to test for items that are Uninitialized and if so handle gracefully.
I agree with @ben_jones12, your rules are triggering before your persistence is done loading your item’s last state. I’m willing to bet you have more than one rules and items files.
I solved the problem by changing the polling period in openHAB.cfg to make sure that items and persistence gets loaded first all the way and rules and sitemap get loaded last. With my setup I have each five seconds longer polling period than the previous one. You may need to experiment.
thank you @ben_jones12 & @rlkoshak!
ok, that makes sense. I’ll try adjusting the polling period. these errors just occurred recently, there were no problems for nearly one year. so maybe I added too many items and rules over time and now it’s too much… :smile:
thanks for your help!
