Create a new org.openhab.ui-x.y.z.jar
Can someone point me to instruction on how to build a new jar for the UI bundles.
I was able to produce the content of org.openhab.ui/web/ folder using the command “npm run build:prod”.
I have something in the folder that look like the contents of the app/ folder in the jar.
But I don’t know how to package the new jar.
Thanks,
Laurnet.
The JAR is generated by the Maven build. So if you have Java and Maven installed you run:
mvn clean install
See:
https://github.com/openhab/openhab-webui?tab=readme-ov-file#command-line-build
Hello Wouter,
Thanks for you quick reply.
I’m stupid, just miss a so simple thing :slight_smile:
Laurent.
