Since, Authentication API for ESH code is merged, can we create, login and access roles from Habpanel to access ESH/OH2.
Thanks.
Thanks.
There is nothing in the REST API regarding authentication at the moment, and I’m note sure the authentication feature is really useable.
HABPanel will eventually be able to authenticate an user and retrieve the roles (what to do with them is tbd), user and role management on the other hand is clearly outside HABPanel’s scope as a UI for daily use, and would be better suited for an administration UI i.e. Paper UI.
