- Platform information:
- Docker
- openHAB version: 3.2.0
- Issue of the topic: rollershutter controll
UID: mqtt:topic:mqtt-broker:esp-velux
label: esp-velux
thingTypeUID: mqtt:topic
configuration:
payloadNotAvailable: Offline
availabilityTopic: tele/esp_velux/LWT
payloadAvailable: Online
bridgeUID: mqtt:broker:mqtt-broker
channels:
- id: velux_bad_up
channelTypeUID: mqtt:switch
label: velux_bad_up
description: ""
configuration:
commandTopic: cmnd/esp_velux/POWER4
stateTopic: stat/esp_velux/POWER4
off: "0"
on: "1"
- id: velux_bad_hold
label: velux_bad_hold
description: null
configuration:
commandTopic: cmnd/esp_velux/POWER5
stateTopic: stat/esp_velux/POWER5
off: "0"
on: "1"
- id: velux_bad_down
label: velux_bad_down
description: null
configuration:
commandTopic: cmnd/esp_velux/POWER6
stateTopic: stat/esp_velux/POWER6
off: "0"
on: "1"
- id: velux_kueche_up
label: velux_kueche_up
description: null
configuration:
commandTopic: cmnd/esp_velux/POWER7
stateTopic: stat/esp_velux/POWER7
off: "0"
on: "1"
- id: velux_kueche_hold
label: velux_kueche_hold
description: null
configuration:
commandTopic: cmnd/esp_velux/POWER8
stateTopic: stat/esp_velux/POWER8
off: "0"
on: "1"
- id: velux_kueche_down
label: velux_kueche_down
description: null
configuration:
commandTopic: cmnd/esp_velux/POWER9
stateTopic: stat/esp_velux/POWER9
off: "0"
on: "1"
- id: velux_wohnzimmer_up
label: velux_wohnzimmer_up
description: null
configuration:
commandTopic: cmnd/esp_velux/POWER1
stateTopic: stat/esp_velux/POWER1
off: "0"
on: "1"
- id: velux_wohnzimmer_hold
label: velux_wohnzimmer_hold
description: null
configuration:
commandTopic: cmnd/esp_velux/POWER2
stateTopic: stat/esp_velux/POWER2
off: "0"
on: "1"
- id: velux_wohnzimmer_down
label: velux_wohnzimmer_down
description: null
configuration:
commandTopic: cmnd/esp_velux/POWER3
stateTopic: stat/esp_velux/POWER3
off: "0"
on: "1"
Now I did not understand how to create a rollershutter channel… I’ve got three Shutters, that can be controlled through three relays (UP, DOWN, STOP (all pulsed)).
Is there a way to configure a rollershutter channel to use three relays?
My rollerhutters are controlled with an esp flashed with tasmota.
{"HeapUsed":3,"Objects":48},"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","POWER5":"OFF","POWER6":"OFF","POWER7":"OFF","POWER8":"OFF","POWER9":"OFF"
Hope you understand my problem, if not I can provide more information!
