I would like to have openHAB create tasks in my Microsoft To-Do (also known as Outlook Tasks) for certain things - for instance, when a battery gets below a certain setpoint, I’d like to create a task in my to-do to have the battery replaced.
Does anyone have any idea how to make this happen via openHAB? There’s a functional Exchange API that could work, but I have no clue how to try to access that reliably via openHAB rules.
I don’t have experience with doing that a trial that I did did not work because I do not have admin permissions in azure to create an application id.
In general you should be able to use python e.g. by using the exec binding resp. executeCommandLine action.
A set of documents that may help are:
fwiw here my solution on how to add Microsoft ToDo tasks. you can use that to add tasks also (as a shopping list basically is a task). Tasks can have times also.
