I could use help creating a rule with a while loop. It’s just a test of how the whole thing works and not a real practical application yet. Nevertheless, I already have a few ideas in mind.
Let me explain what I’m trying to accomplish:
while(condition == true) {
// do work
Thread::sleep(1)
if (isRunningExampleRule.state == OFF) {
condition = false
logInfo("example rule", "Greetings from example rule")
I have a trigger (exampleRuleTrigger
) that executes a rule. This is simplified also only a switch. Then I have another switch (isRunningExampleRule
) that I want to use as a termination condition in this rule.
I tried following:
rule "example rule"
Item exampleRuleTrigger changed to ON
logInfo("example rule", "execution of example rule is started")
var condition = true
timer = createTimer(now.plusSeconds(1), [ |
// do work
condition = false
if (condition == false) {
timer = null
timer.reschedule(now.plusSeconds(1))
logInfo("example rule", "execution of example rule is finished")
But I will receive following error:
06:10:36.028 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'exampleRuleTrigger' received command ON
06:10:36.034 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'exampleRuleTrigger' changed from OFF to ON
06:10:36.085 [INFO ] [penhab.core.model.script.example rule] - execution of example rule is started
06:10:36.094 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'rules-1' failed: An error occurred during the script execution: Couldn't invoke 'assignValueTo' for feature JvmVoid: (eProxyURI: rules.rules#|::0.2.0.2.0.2::0::/1) in rules
06:10:37.087 [INFO ] [penhab.core.model.script.example rule] - Greetings from example rule
06:10:37.091 [WARN ] [core.internal.scheduler.SchedulerImpl] - Scheduled job '<unknown>' failed and stopped
java.lang.reflect.UndeclaredThrowableException: null
at com.sun.proxy.$Proxy142.apply(Unknown Source) ~[?:?]
at org.openhab.core.model.script.actions.ScriptExecution.lambda$0(ScriptExecution.java:97) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:191) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:88) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: org.openhab.core.model.script.engine.ScriptExecutionException: The name 'timer' cannot be resolved to an item or type; line 78, column 9, length 5
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1008) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:971) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:247) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:874) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:47) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:30) ~[?:?]
Note: the state of isRunningExampleRule
is still ON
If I change timer = ...
to var timer = ...
06:12:35.518 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'rules.rules', using it anyway:
The value of the local variable timer is not used
06:13:17.813 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'exampleRuleTrigger' received command ON
06:13:17.821 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'exampleRuleTrigger' changed from OFF to ON
06:13:17.925 [INFO ] [penhab.core.model.script.example rule] - execution of example rule is started
06:13:17.929 [INFO ] [penhab.core.model.script.example rule] - execution of example rule is finished
06:13:18.929 [INFO ] [penhab.core.model.script.example rule] - Greetings from example rule
06:13:18.931 [WARN ] [core.internal.scheduler.SchedulerImpl] - Scheduled job '<unknown>' failed and stopped
... 10 more
Instead of true
and false
I tried it with 1
and 0
Of course if it would work the loop can be simplified to
// do work
if(isRunningExampleRule.state == ON) timer.reschedule(now.plusSeconds(1))
else timer = null
Obviously I am too stupid to write a While loop.
Thanks in advance.
