Creating charts/graphs? - error
I’m just trying to create a small chart for testing and I can’t seem to create the chart/graph. My MySQL persistence is working and is able to receive data. I am unsure as to how to fix the problems. I can provide more information if need be.
I get these error/warning/info:
[INFO ] [ui.internal.chart.ChartServlet] - Illegal argument in chart: {}
java.lang.IllegalArgumentException: Series name cannot be null or zero-length!!!
at com.xeiam.xchart.Series.(Series.java:84) ~[na:na]
at com.xeiam.xchart.internal.chartpart.AxisPair.addSeries(AxisPair.java:102) ~[na:na]
at com.xeiam.xchart.Chart.addSeries(Chart.java:115) ~[na:na]
at org.openhab.ui.internal.chart.DefaultChartProvider.addItem(DefaultChartProvider.java:354) ~[na:na]
at org.openhab.ui.internal.chart.DefaultChartProvider.createChart(DefaultChartProvider.java:184) ~[na:na]
at org.openhab.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:245) ~[na:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735) [javax.servlet_3.0.0.v201112011016.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848) [javax.servlet_3.0.0.v201112011016.jar:na]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.Server.handle(Server.java:350) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at java.lang.Thread.run(Unknown Source) [na:1.8.0_91]
[WARN ] [e.jetty.servlet.ServletHandler] - /chart
[WARN ] [.c.p.RetrieveRemoteDescriptors] - Device descriptor retrieval failed, no response: http://192.168.2.254:80/igd.xml
Can you post your sitemap that contains the Chart widget?
sitemap demo label=“REU”
Frame label=“Arduino Graph”
Chart label=“Weight” item=Weight period=h refresh=2000
Is MySQL set as your default persistence service in openhab.cfg? If not, try adding service="mysql" as described here.
Yes it is set as default:
persistence:default=mysql
Also when I put down
service = “mysql”
the sitemap doesn’t render the chart at all.
My Chart widgets don’t have label=... sections. Could you remove label=... and service=... from your Chart widget and see if that helps?
Ok, I’ll try that out when I get a chance.
I set up the same system on my laptop, now it says:
and the chart/graph doesn’t post on the sitemap. Granted data isn’t currently being sent to my database for some reason. I’ll try to fix it asap, and come back.
java.lang.IllegalArgumentException: Persistence service not found ‘mysql’.
at org.openhab.ui.internal.chart.DefaultChartProvider.createChart(DefaultChartProvider.java:176) ~[na:na]
I’ve fixed the database problem, but the chart still doesn’t post data. The chart is there but there is no data on it.
Have you checked the label in the items definitions ? Had this same issue and then discovered after many days the mistake I made in the definition file:
I had ‘Number Temp1_temperature “[Temperature %.1f °C]”’ and when I changed it to ‘Number Temp1_temperature “Temperature [%.1f °C]”’ the problem was fixed (because what is between is the formatted value and the rest is the ‘Series name’, so it was null.
Currently this is what I have:
Items:
Group arduino
String Arduino “Arduino [%s]” (arduino) { serial=“COM3” }
Number Weight " [%s]" (arduino)
Sitemap:
Frame label=“Arduino”
Text label=“Weight” item=Arduino
I’ve fixed the null part but the chart still doesn’t post the desired data but the chart is visible.
Any ideas why it is or how to fix it?
I’ve seen a case before where items were persisted to MySQL, but then the user later changed the item type and this stopped the MySQL persistence service from being able to store new values because the SQL table definition was no longer compatible with the item’s states. Check you MySQL table definitions and look for mismatched SQL types and item types.
Another issue is that you are using %s in your Weight item’s label, but it’s a Number item, so you should use either %d, %.1f or similar numeric format.
Mysql isn’t really suitable for charts. Preferred way is to use round robin databases (RRD). These work well with fixed intervals.
I came across your topic because I’m getting this error
[WARN ] [thome.ui.internal.chart.ChartServlet] - Chart generation failed: java.lang.String cannot be cast to java.lang.Number
But this does not seem related. Hope my comment helps you though. I ran into similar issues when I was starting out with charts :slight_smile:
