Hello all,
I try to count my total energy need in my house by using zwave sensors for the domestic plugs. The sensors are all called
Z_way_number_WallPlug(x)_totalpower [(x) = the number of the plug] which gave me a total energy flown through the plug back.
In my example I use only 2 plugs but t should aterwards easy to extend to more plugs.
My idea is first to calculate the daily total energy by subtraction the actual value by the value of yesterday:
rule "set number_wallplug2dailytotalenergy"
Item Z_way_number_WallPlug2_totalpower changed
try{
if (Z_way_number_WallPlug2_totalpower != NULL && Z_way_number_WallPlug2_totalpower != UNDEF) {
if (Z_way_number_WallPlug2_totalpower.state != NULL && Z_way_number_WallPlug2_totalpower.state != UNDEF)
var local_time_yesterday = now.with(LocalTime.of(0, 0, 0, 0)).minusMinutes(1)
var Number local_number_wallplug2dailytotalenergy = (Z_way_number_WallPlug2_totalpower.state as Number) - (Z_way_number_WallPlug2_totalpower.historicState(local_time_yesterday).state as Number)
number_wallplug2dailytotalenergy.postUpdate(local_number_wallplug2dailytotalenergy)
logInfo("set number_wallplug2dailytotalenergy", local_number_wallplug2dailytotalenergy.toString())
else
number_wallplug2dailytotalenergy.postUpdate(0)
else
catch(Throwable T)
logError("Error", "Some bad stuff happened in \"set number_wallplug2dailytotalenergy\": " + T.toString)
finally
rule "set number_wallplug3dailytotalenergy"
Item Z_way_number_WallPlug3_totalpower changed
try{
if (Z_way_number_WallPlug3_totalpower != NULL && Z_way_number_WallPlug3_totalpower != UNDEF) {
if (Z_way_number_WallPlug3_totalpower.state != NULL && Z_way_number_WallPlug3_totalpower.state != UNDEF)
number_wallplug3dailytotalenergy.postUpdate(local_number_wallplug3dailytotalenergy)
logInfo("set number_wallplug3dailytotalenergy", local_number_wallplug3dailytotalenergy.toString())
else
number_wallplug3dailytotalenergy.postUpdate(0)
else
catch(Throwable T)
logError("Error", "Some bad stuff happened in \"set number_wallplug3dailytotalenergy\": " + T.toString)
finally
Then calculate the sum of all plugs for the totaly daily energy
rule "set number_dailytotalenergy"
Item number_wallplug2dailytotalenergy changed OR
Item number_wallplug3dailytotalenergy changed
try{
if (number_wallplug2dailytotalenergy != NULL && number_wallplug2dailytotalenergy != UNDEF &&
number_wallplug3dailytotalenergy != NULL && number_wallplug3dailytotalenergy != UNDEF) {
if (number_wallplug2dailytotalenergy.state != NULL && number_wallplug2dailytotalenergy.state != UNDEF &&
number_wallplug3dailytotalenergy.state != NULL && number_wallplug3dailytotalenergy.state != UNDEF){
var Number local_number_dailytotalenergy = (number_wallplug2dailytotalenergy.state as Number) + (number_wallplug3dailytotalenergy.state as Number)
number_dailytotalenergy.postUpdate(local_number_dailytotalenergy)
logInfo("set number_dailytotalenergy", number_dailytotalenergy.state.toString())
else
number_dailytotalenergy.postUpdate(0)
logInfo("set number_dailytotalenergy", number_dailytotalenergy.toString())
else
catch(Throwable T)
logError("Error", "Some bad stuff happened in \"set number_dailytotalenergy\": " + T.toString)
finally
and on midnight reset the daily energy and caluclate the monthly total energy by add the old monthly value with the new daily value
rule "set local_number_monthlytotalenergy reset number_wallplugdailytotalenergy"
Time is midnight
try{
if(number_monthlytotalenergy.state != NULL && number_monthlytotalenergy.state != UNDEF &&
number_dailytotalenergy.state != NULL && number_dailytotalenergy.state != UNDEF)
var Number local_number_monthlytotalenergy = (number_monthlytotalenergy.state as Number) + (number_dailytotalenergy.state as Number)
number_monthlytotalenergy.postUpdate(local_number_monthlytotalenergy)
logInfo("set local_number_monthlytotalenergy reset number_wallplugdailytotalenergy", local_number_monthlytotalenergy.toString())
else
number_monthlytotalenergy.postUpdate(0)
logInfo("set local_number_monthlytotalenergy reset number_wallplugdailytotalenergy", number_monthlytotalenergy.state.toString())
catch(Throwable T)
logError("Error", "Some bad stuff happened in \"set local_number_monthlytotalenergy reset number_wallplugdailytotalenergy\": " + T.toString)
finally
and on 2minutes after midnight 1st january every year calculating the energy over the past years:
rule "set number_overalltotalenergy reset number_yearlytotalenergy"
Time cron "0 2 0 1 1 ? * ?"
try{
if(number_overalltotalenergy.state != NULL && number_overalltotalenergy.state != UNDEF &&
number_yearlytotalenergy.state != NULL && number_yearlytotalenergy.state != UNDEF)
var Number local_number_overalltotalenergy = (number_overalltotalenergy.state as Number) + (number_yearlytotalenergy.state as Number)
number_overalltotalenergy.postUpdate(local_number_overalltotalenergy)
number_yearlytotalenergy.postUpdate(0)
logInfo("set number_overalltotalenergy reset number_yearlytotalenergy", local_number_overalltotalenergy.toString())
else
number_overalltotalenergy.postUpdate(0)
logInfo("set number_overalltotalenergy reset number_yearlytotalenergy", number_overalltotalenergy.state.toString())
catch(Throwable T)
logError("Error", "Some bad stuff happened in \"set number_overalltotalenergy reset number_yearlytotalenergy\": " + T.toString)
finally
How do you thing about my soultion do you have any help for me to make it better? Or any better solution?
