Issue of the topic:
So I recently created a OH-system, connected my first items and was right on track to create a Sitemap.
Now to my problem: I don’t know where to put the Sitemap-file, if I have a look on the SD Card of the Raspberry there is only the available boot-partition accessible, no other partition is shown. Where do I put my sitemap then. - Is a solo Raspbian openhab config bad, in terms of using files for configuration?
That is because they do not recognize Linux partitions.
It might be easier for you to use the openHABian image. It simplifies setting up openHAB and you can set up SAMBA to access the configuration files from Windows or, I believe, MAcOS.
