Cron driven rule settings revert to default settings when viewed/edited via graphical UI - why?
I created a simple rule to ‘turn a kasa plug’ on with the following cron settings (via the UI):
Turn on 3 seconds, 13 mins, 10 hour, every day, every month, every year.
I save the rule, test it, works fine.
I navigate back to the Rules section and see all the rules I created.
I select the ‘turn on kasa plug’ rule again and when I open the cron window, all the settings revert to the default, 0 seconds, 0 mins, 8 hour, every day, every month, every year.
Why do my previously defined time of day settings disappear from the build window??
This is really annoying because if I want to change a parameter, e.g. change all months to June for example, it forces you to remember what all the previous setting were because if you make the change to the month, and save it, the time of day (sec, min, hrs) have been changed back to the defaults and my original settings are gone.
Forgive the harsh eval, but this is plain stupid.
No, it’s just a UI bug, these things happen. Please file an issue in the UI repository.
