I had a full system crash and recovered only the conf and userdata. Now I got the following error:
2018-05-14 17:09:02.290 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=349, bundle=218/mvn:org.openhab.binding/org.openhab.binding.intertechno/1.11.0]: Unexpected problem updating configuration org.openhab.culintertechno
at org.openhab.binding.intertechno.internal.CULIntertechnoBinding$1.open(CULIntertechnoBinding.java:64) [218:org.openhab.binding.intertechno:1.11.0]
at org.openhab.io.transport.cul.CULLifecycleManager.open(CULLifecycleManager.java:92) [219:org.openhab.io.transport.cul:1.11.0]
at org.openhab.io.transport.cul.CULLifecycleManager.config(CULLifecycleManager.java:74) [219:org.openhab.io.transport.cul:1.11.0]
at org.openhab.binding.intertechno.internal.CULIntertechnoBinding.updated(CULIntertechnoBinding.java:147) [218:org.openhab.binding.intertechno:1.11.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
My config looks like:
############################# Intertechno Binding ###################################
# Devicename to use (mandatory)
# Example /dev/ttyACM0
device=serial:/dev/ttyAMA0
# How often should the command be repeated? (optional)
# See http://culfw.de/commandref.html for details
repetitions=6
# How long should one pulse be? (optional)
wavelength=420
My ttys are looking like:
crw-rw---- 1 root dialout 166, 0 May 14 17:13 /dev/ttyACM0
crwxrwxrwx 1 root dialout 204, 64 May 14 16:36 /dev/ttyAMA0
crw------- 1 root root 5, 3 May 14 16:36 /dev/ttyprintk
I also checked the group of dialout
dialout:x:20:openhabian,openhab
What can I do? Did I forgot something?
Greetz
HFM
