Curl Header Response
is there a way to get the response header from a curl into a variable?
The response header of my request contains information I need to use in another rule.
Please show us how you use curl in a rule.
Yes …
Example for BASH
#!/bin/bash
RESPONSE_VAR=$(curl REQUESTURL)
curl -X POST --header "Content-Type: text/plain" --header "Accept: application/json" -d $RESPONSE_VAR "http://OPENHAB_IP:PORT/rest/items/OPENHAB_ITEM"
Perhaps you must modify or transform the Response, this is only an Example
