Custom Icons: no dynamic icon in Locations
I customized the heating icons and placed them in the /conf/icons/classic/ folder with a unique name:
Now it is working fine under weUI->Settings->Items
But it is not working in the Location Cards:
grafik
I have no idea, could someone help me please?
Thanks :slight_smile:
iconUseState is not enabled for number items in the default model lists.
If you select go to the item’s Default List Item Widget metadata, you will see that you can manually configure some settings including turning on iconUseState.
