Thank you @daabm! You could also use a persistence provider to restore the presets at startup, that is what I do.
Did that - thanks for putting me on the right track Never thought about persistence before
Firstly: Thank you to DrRSatzteil; this is very handy!
I am stuck on this⦠sorry
Hereās how I understood to create the string item for 4:
I am pretty sure, I did not put the ā||⦠with Num1/2/3⦠being a number between 0 and 100ā correctly, but after trying and trying I canāt figure it out.
When I click on āPresetsā in the widget, nothing happens.
Or if the presets wonāt work: How could I remove the part with the presets from the widget?
(My config: Windows 10 computer; Openhab 4.0.4)
the string item can have any label you want so you can give it a meaningful name. I admit that this is pretty misleading in my description, you donāt have to care about the format at all as it is all taken care of by the rules.
Donāt give up just yet though. Iām pretty sure we can get you there. Could you show you widget configuration and also confirm that you also installed the second widget from the original post?
Wow, now thatās instant support. Thank you!
I did indeed completely overread the 2nd widget. The popover opens now!
Now, it looks like in Post 9/44:
However, I canāt change it (click on add does nothing - swipe and delete for the wrong entry does nothing).
EDIT (I had a log posted but it was due to wrong ECMA version): I figured out how to set the scripting setting to ECMA 5.1 (needed to install Nashorn).
Now it does not do anything, but the log also shows nothing.
Oh this looks good so far. Just to make sure that it really isnāt working yet:
If you change the blinds position to letās say 40% (or any other value) and the click on the āAddā button the list should be updated with a value of 40%.
If you swipe the initial NULL entry to the left you should see a button that allows you to delete this preset.
If these things are not working there is still something wrong with the scripts or with the widget configuration.
Hereās my setup:
The three items for 4, 5 and 6:
The rule āadd Presetsā
configuration: {}
triggers:
- id: "2"
configuration:
itemName: Storen_Preset_add_preset
type: core.ItemCommandTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript;version=ECMAScript-5.1
script: >-
var currentPresets =
ir.getItem('Storen_Preset_add_preset').state.toString()
var presetsArray = currentPresets.split('|')
var index = presetsArray.indexOf(command.toString().split(".")[0])
if (index < 0) {
presetsArray.push(command.toString().split(".")[0])
presetsArray.sort(function(a, b) {
return a - b;
var newPresets = presetsArray.join("|")
events.sendCommand(ir.getItem('Storen_Preset_add_preset'), newPresets)
type: script.ScriptAction
The rule ādelete Presetsā
configuration: {}
triggers:
- id: "2"
configuration:
itemName: Storen_Preset_delete_preset
conditions: []
actions:
- inputs: {}
configuration:
script: >-
ir.getItem('Storen_Preset_delete_preset').state.toString();
var presetsArray = currentPresets.split('|');
var index = presetsArray.indexOf(command.toString().split(".")[0]);
if (index > -1) {
presetsArray.splice(index, 1);
var newPresets = presetsArray.join("|");
events.postUpdate(ir.getItem('Storen_Preset_delete_preset'), newPresets);
Problem:
When I click āaddā in the presets popover, nothing happens.
When I swipe the āNULL%ā and click delete, nothing happens.
No log entry that seems to be associated with this widget.
Please change the following:
In the add rule change the name of the item in the first and the second to last line to āStoren_Presetā. The item referenced there should be the item that stores all your presets as an array. Iām only talking about the script code, leave the trigger as it is now.
The same applies to the delete rule. Also use Storen_Preset there and you should be good.
Oooh, I was stupid/not reading correctly. Sorry!
It really works now! And I learned something about ECMA-versions. Thereās still so much to learn. Since I am not a programmer and wonāt ever be (but still appreciate to be able to customize stuff), I am very grateful for developers like you who put their products out in the world for free for the crowd and then indulge with our stupid questions.
Thank you very much for the widget and the support and have a great sunday!
I have read through all the instructions carefully and implemented them (at least I think so).
Nevertheless, I cannot add any presets.
- i copied the widgets from above and created them with the same names.
- the elements awning_presets, awning_add_presets, awning_del_presets are created and positioned accordingly in the configurations.
Nevertheless, I cannot save any presets.
There are a total of 4 awnings, all of which have their own items and rules.
Can the widget be used for multiple awnings?
configuration: {}
triggers:
- id: "1"
configuration:
itemName: Markise1_add_presets
conditions: []
actions:
- inputs: {}
configuration:
script: |-
var currentPresets = ir.getItem('Markise1_presets').state.toString()
if (index < 0) {
return a - b;
events.sendCommand(ir.getItem('Markise1_presets'), newPresets)
Das Widget:
component: widget:universal_shutter_v4
add_preset: Markise1_add_presets
control: Markise_Unterdach_Control
delete_preset: Markise1_del_presets
footer: '=(items.Markise_Unterdach_Control.state.toString().split(".")[0]) == 0
? "Offen" :
(items.Markise_Unterdach_Control.state.toString().split(".")[0])== 100 ?
"Geschlossen" : ((items.Markise_Unterdach_Control.state).split(".")[0] + "%
geschlossen")'
moving: "false"
position: Markise_Unterdach_Control
presets: Markise1_presets
title: Unterdach
Except that several widgets on one page do not work, I can not think of or notice.
Interesting that the position values are stored in the items Markise_Add_Presets, but not with ā|ā characters.
Many thanks for your help!
The widget may be used for as many awnings as you like so there is no limitation to only one widget per page.
Iād say your rule and widget looks good, can you please show your item definitions?
here the item definitions:
label: Markise 1 Presets
type: String
category: ""
groupNames: []
tags: []
label: Markise 1 Add Presets
type: String
category: ""
groupNames: []
tags: []
label: Markise 1 delete Presets
type: String
category: ""
groupNames: []
tags: []
I think, there is nothing special.
Thank you very much for your quick response!!!
Yes, its that simple. Good⦠whatās the current state of āMarkise 1 Presetsā? Do you have any errors from the execution of the rule in the logs?
Oh and tell me what happens when you try to do so: you know that you can only add a preset when the current state of the awning is different from an already existing preset. So make sure that the control of the awning works as expected
in the event log are a lot of items:
[INFO ] [openhab.event.ItemCommandEvent ] - Item 'Markise4_del_presets' received command NULL
[INFO ] [openhab.event.ItemCommandEvent ] - Item 'Markise4_add_presets' received command 65
[INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Markise4_add_presets' changed from 66 to 65
[INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Markise2_presets' changed from 36 to 55
[INFO ] [openhab.event.ItemCommandEvent ] - Item 'Markise2_presets' received command 55
[INFO ] [openhab.event.ItemCommandEvent ] - Item 'Markise3_del_presets' received command NULL
[INFO ] [openhab.event.ItemCommandEvent ] - Item 'Markise4_add_presets' received command 0
[INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Markise2_del_presets' changed from 36 to 55
[INFO ] [openhab.event.ItemCommandEvent ] - Item 'Markise2_del_presets' received command 55
interestingly, one widget contains a value, all other 3 show āNULL%ā for no element I can add a value, nor delete; although other positions are approached.
My openhab has version 4.2.1 and runs as a docker image on a QNAP.
This looks good except for Markise 2. It seems that you used the Markise2_presets item instead of the Markise2_add_presets item (just a guess).
But for Markise 4 I can see that your add_presets item receives commands as expected. After that, the rule should be triggered to change the Markise4_presets item state. Can you verify that the rule is running? Do you have a command to the Markise4_add_presets item set as trigger for the rule? Is anything in the openhab.log when you add a preset?
Now I have installed a switch to trigger the rule, unfortunately without success.
I have found the following entry in the openhab.log:
[e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Verikal_Markise_vorne_Links_Control
This is all very strange
Iāll start the container again (but not until tonight)
[e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesnāt exist: Verikal_Markise_vorne_Links_Control
This usually means that you configured an item in a widget that does not exist (anymore). Itās probably not related especially since you have multiple devices.
I was wondering, does the āreleaseOnly: trueā command work in this widget? If not, how can we add it because itās a MUST, otherwise when using the slider itās sending multiple commands.
I havenāt tried but you should be able to add this line to the config of the oh-slider component:
releaseOnly: true
