Hi All,
Not sure if this is the correct area for this post.
I have made a custom widget which is working pretty well, this is what it looks like:
It is showing my total electricity usage in the middle, with the 3 sub areas underneath showing each of my 3 electricity phases.
Also, the top band shows generation (currently zero).
I would like to be able to click on different parts of the diagram to show more detail (pretty standard!).
However, I cannot get any actions to trigger, I have played with z-index and tried to see using the browser inspect, but I can’t seem to find the issue.
Can someone help?
Here is the code:
uid: Energy_Meter
tags:
- list
props:
parameters:
- default: "350"
description: Visual size of the control in px (default 400)
label: size [px]
required: false
type: TEXT
- context: item
default: ssOwl_Phase1
description: Red
label: Item
required: false
type: TEXT
- context: item
default: ssOwl_Phase2
description: White
label: Item
required: false
type: TEXT
- context: item
default: ssOwl_Phase3
description: Black
label: Item
required: false
type: TEXT
- context: item
default: ssOwl_Energy
description: Total
label: Item
required: false
type: TEXT
- context: item
default: Rez_External_Switch_Electric_meter_watts
description: Generated
label: Item
required: false
type: TEXT
timestamp: Sep 25, 2024, 9:54:56 PM
component: f7-card
action: popup
actionPage: page:Energy_Red
actionPageTransition: f7-parallax
slots:
default:
- component: f7-card-content
style:
z-index: 1
slots:
default:
- component: oh-context
functions:
consumptionColorPhase: "=(x) => (x >= 3000) ? '#ff3333' : (x >= 2500) ?
'#ff7a33' : (x >= 2000) ? '#ff8633' : (x >= 1500) ? '#ff9633'
: (x >= 1300) ? '#ffa533' : (x >= 1100) ? '#ffaf33' : (x >=
900) ? '#ffbb33' : (x >= 700) ? '#ffc133' : (x >= 500) ?
'#ffc733' : (x >= 400) ? '#ffd133' : (x >= 300) ? '#ffda33' :
(x >= 200) ? '#ffe333' : (x >= 100) ? '#ffec33' : (x >= 0) ?
'#fcff33' : 'white'"
consumptionColorTotal: "=(x) => (x >= 7000) ? '#ff3333' : (x >= 6000) ?
'#ff7a33' : (x >= 5500) ? '#ff8633' : (x >= 5000) ? '#ff9633'
: (x >= 4500) ? '#ffa533' : (x >= 4000) ? '#ffaf33' : (x >=
3500) ? '#ffbb33' : (x >= 3000) ? '#ffc133' : (x >= 2500) ?
'#ffc733' : (x >= 2000) ? '#ffd133' : (x >= 1500) ? '#ffda33'
: (x >= 1000) ? '#ffe333' : (x >= 500) ? '#ffec33' : (x >= 0)
? '#fcff33' : 'white'"
genColor: "=(x) => (x <= -600) ? '#00ff00' : (x <= -550) ? '#17ef19' : (x <=
-500) ? '#25e527' : (x <= -450) ? '#2fdb31' : (x <= -400) ?
'#36d137' : (x <= -350) ? '#3bc73d' : (x <= -300) ? '#3fbb40'
: (x <= -250) ? '#44b245' : (x <= -200) ? '#44a645' : (x <=
-150) ? '#459d46' : (x <= -100) ? '#449145' : (x <= -50)
? '#428243' : (x <= -20) ? '#407641' : (x <= 0)
? '#406041' : 'white'"
variables:
test: 56
slots:
default:
- component: f7-row
class:
- justify-content-center
resizable-absolute: true
resizableFixed: true
action: popup
slots:
default:
- component: f7-block
action: popup
class: energy
style:
--f7-block-margin-vertical: 0px
--f7-block-padding-horizontal: 0px
--f7-block-padding-vertical: 0px
background: rgb(0,60,77)
border: 6px solid rgb(60, 60, 77)
border-radius: 50%
flex-shrink: 0
height: "=props.size ? Number(props.size)+'px' : '400px'"
padding-left: 0px
width: "=props.size ? Number(props.size)+'px' : '400px'"
slots:
default:
- component: oh-gauge
comment: ====================Total==================
action: popup
borderBgColor: black
borderColor: =fn.consumptionColorTotal(Number.parseFloat(items[props.TotalActual].state))
borderWidth: 10
item: =props.TotalActual
max: 6000
style:
left: 0%
position: absolute
top: 7%
z-Index: 1
type: circle
valueFontSize: 60
valueFontWeight: bold
valueText: =@props.TotalActual
valueTextColor: rgb(180,180,180)
comment: =====================Red=====================
action: popup
borderColor: =fn.consumptionColorPhase(Number.parseFloat(items[props.RedActual].state))
borderWidth: 10
item: =props.RedActual
labelFontSize: 25
labelText: Red
labelTextColor: rgb(180,180,180)
max: 2000
style:
height: "=props.size ? Number(props.size)*0.4+'px' : '400px'"
left: 0%
position: absolute
top: 50%
transform: translate(-27%,-10%) rotate(68deg)
width: "=props.size ? Number(props.size)*0.4+'px' : '400px'"
z-Index: 999 !important
type: semicircle
valueFontSize: 25
valueText: =@props.RedActual
comment: ====================White====================
action: popup
actionPage: page:Energy_White
borderColor: =fn.consumptionColorPhase(Number.parseFloat(items[props.WhiteActual].state))
borderWidth: 10
item: =props.WhiteActual
labelFontSize: 25
labelText: White
max: 2000
style:
left: 3%
position: absolute
top: 50%
transform: translate(170%,-10%) rotate(292deg)
z-Index: 20
type: semicircle
valueFontSize: 25
valueText: =@props.WhiteActual
comment: ====================Black====================
action: popup
actionPage: page:Energy_Black
borderColor: =fn.consumptionColorPhase(Number.parseFloat(items[props.BlackActual].state))
borderWidth: 10
item: =props.BlackActual
labelFontSize: 25
labelText: Black
max: 2000
style:
left: 30%
position: absolute
top: 73%
z-Index: 20
type: semicircle
valueFontSize: 25
valueText: =@props.BlackActual
comment: ==================== Generated ====================
action: popup
borderBgColor: =fn.genColor(Number.parseFloat(items[props.TotalGenerated].state))
borderColor: black
borderWidth: 10
item: =props.TotalGenerated
labelFontSize: 16
labelText: " "
max: 1
min: -600
style:
borderBgColor: -webkit-linear-gradient(left, rgb(0, 255, 0) 20%,rgb(40, 10, 40)
100%)
height: "=props.size ? Number(props.size)*0.44+'px' : '400px'"
left: 0%
position: absolute
top: 6%
transform: rotateY(0deg) scale(118%,118%)
z-index: 1
type: semicircle
valueFontSize: 20
valueText: =@props.TotalGenerated.state
valueTextColor: =fn.genColor(Number.parseFloat(items[props.TotalGenerated].state))
