alexxio
(Alessio)
September 6, 2020, 8:00pm
1
Hello everybody,
I’ve wanted to explore HABPanel and his custom widget feature, this is my first attempt so be kind if something does not work..I don’t know even if I can help troubleshooting
So I tried with a Remote for Samsung TV (tested on my tablet: Samsung Tab 4 10’')
Many credits go to Andy ( See this post ) . I took his template for the basic structure and swipe functionalty.
The widget settings are quite self explanatory the only requirement is:
TV Keycode Item → KeyCode Item of the Samsung TV binding.
It looks better with a size of 3x2 but it should scale up to any size, it looks decent on my smartphone too.
(screenshot taken with dark material theme but should play well on every “dark” theme).
Here the JSON: Samsung TV Remote.widget.json (12.6 KB)
After I came up with this widget I realized that is not comfortable to have a big widget always occupying my dashboard, so credits to Yannick ( See this post ) I tried to make a nested custom widget to launch the remote on a modal window.
(screenshot of the launcher)
Here the JSON of the remote “launcher” Samsung TV Remote Launcher.widget.json (2.0 KB)
(remote icon I use for the launcher)
If you import both widgets, you only have to put and configure the launcher on your Dashboard.
The launcher config are self explanatory too (I think) but thees ones are mandatory:
TV Remote Widget Name → It’s the name you gave to the remote widget when importing it (change it if you changed the default name while importing the remote widget)
TV KeyCode Item → KeyCode item of the Samsung TV binding
TV Remote Icon → Icon to be displayed in the button
Hope it can be helpful to someone…otherwise…well it’s helpful to me!
Hi Alessio
I am new to openhab. The remote looks really cool. However, I am not clear TV KeyCode Item value I need to provide. is it the binding id samsungtv? I tried it but it’s not working.
alexxio
(Alessio)
April 10, 2021, 1:56pm
3
It’s meant to be working with the Samsung tv binding.
If you have the binding installed create an item linked to the keyCode channel of the binding.
Then provide that item to the widget and it should work.
syntacrsc
(Ralph Schnarkowski)
August 30, 2022, 5:05pm
4
Hi Alessio.
It’s been quite a while since the last post on this topic…
Based on a widget by @Bernd_Ritter I’ve created an alternative Samsung TV Remote widget which works with the “Samsung TV Binding (Beta)” from the Community Marketplace specialized for the Samsung “The Frame”.
It works well on the Samsung Z-Fold mobile phone and on tablets.
Maybe someone finds this helpful!?
Here’s the widget code.
SamsungTheFrameRemoteWidget.txt (51.7 KB)
The image-files need to have the same name as the commands for the channels.
Here’s the rule to send the channel number based on the channel button on the right:
var Timer TVWohnzimmerTimer = null
//Power ON/OFF
rule TV_Wohnzimmer_Power
Item TV_Wohnzimmer_Power changed
if (TVWohnzimmerTimer !== null)
TVWohnzimmerTimer.cancel
if (TV_Wohnzimmer_Power.state == OFF)
TVWohnzimmerTimer = createTimer(now.plusSeconds(3))
[ | if (TV_Wohnzimmer_ArtMode.state == ON)
TV_Wohnzimmer_ArtMode.sendCommand(OFF)
else
TVWohnzimmerTimer = createTimer(now.plusSeconds(5))
[ | TV_Wohnzimmer_KeyCode.sendCommand("")
TV_Wohnzimmer_KeyCode.sendCommand("EXIT")
TVWohnzimmerTimer = createTimer(now.plusSeconds(2))
//Mute-Unmute TV
rule TV_Wohnzimmer_Mute
Item TVC_WohnzimmerMute changed
TV_Wohnzimmer_KeyCode.sendCommand("MUTE")
//Switch to Channel:
rule TVC_WohnzimmerTVChannel
Item TVC_WohnzimmerTVChannel received update
switch (TVC_WohnzimmerTVChannel.state)
case "ARD": { TV_Wohnzimmer_KeyCode.sendCommand("1") }
case "ZDF": { TV_Wohnzimmer_KeyCode.sendCommand("2") }
case "WDR": { TV_Wohnzimmer_KeyCode.sendCommand("3") }
case "RTL": { TV_Wohnzimmer_KeyCode.sendCommand("5") }
case "RTL2": { TV_Wohnzimmer_KeyCode.sendCommand("6") }
case "PRO7": { TV_Wohnzimmer_KeyCode.sendCommand("7") }
case "SAT1": { TV_Wohnzimmer_KeyCode.sendCommand("8") }
case "VOX": { TV_Wohnzimmer_KeyCode.sendCommand("9") }
case "Kabel1": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("0") }
case "SuperRTL": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("1") }
case "DMAX": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("2") }
case "Sport1": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("3") }
case "ArteHD": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("4") }
case "Tele5": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("5") }
case "Kabel1Doku": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("6") }
case "ZDFneo": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("7") }
case "3satHD": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("8") }
case "AlphaHD": { TV_Wohnzimmer_KeyCode.sendCommand("1") TV_Wohnzimmer_KeyCode.sendCommand("9") }
case "ZDFinfoHD": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("0") }
case "N24Doku": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("1") }
case "Tagesschau24HD": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("2") }
case "Phoenix": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("3") }
case "Nitro": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("4") }
case "ToggoPlus": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("5") }
case "KiKAHD": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("6") }
case "Nick": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("7") }
case "RTLup": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("8") }
case "SIXX": { TV_Wohnzimmer_KeyCode.sendCommand("2") TV_Wohnzimmer_KeyCode.sendCommand("9") }
case "7MaxxHD": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("0") }
case "Sat1Gold": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("1") }
case "VOXup": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("2") }
case "BRHD": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("3") }
case "HRHD": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("4") }
case "MDRThueringen": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("5") }
case "NDRHD": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("6") }
case "RbbHD": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("7") }
case "SRHD": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("8") }
//case "": { TV_Wohnzimmer_KeyCode.sendCommand("3") TV_Wohnzimmer_KeyCode.sendCommand("9") }
case "AnixeHD": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("0") }
case "OneHD": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("1") }
case "ServusTVHD": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("2") }
case "WeltDerWunder": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("3") }
case "Aljazeera": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("4") }
case "BBCWorldNews": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("5") }
case "Bloomberg": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("6") }
case "CNBCEurope": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("7") }
case "CNews": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("8") }
case "CNN": { TV_Wohnzimmer_KeyCode.sendCommand("4") TV_Wohnzimmer_KeyCode.sendCommand("9") }
case "Euronews": { TV_Wohnzimmer_KeyCode.sendCommand("5") TV_Wohnzimmer_KeyCode.sendCommand("0") }
case "NHKWorld": { TV_Wohnzimmer_KeyCode.sendCommand("5") TV_Wohnzimmer_KeyCode.sendCommand("1") }
case "SkyNews": { TV_Wohnzimmer_KeyCode.sendCommand("5") TV_Wohnzimmer_KeyCode.sendCommand("2") }
TV_Wohnzimmer_KeyCode.sendCommand("ENTER")
And the items file:
Switch TVC_WohnzimmerMute "Mute"
String TVC_WohnzimmerTVChannel "Kanal"
Dimmer TV_Wohnzimmer_Volume "Volume" <soundvolume> (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:volume"}
Switch TV_Wohnzimmer_Mute "Mute" <soundvolume_mute> (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:mute"}
Dimmer TV_Wohnzimmer_Brightness "Brightness" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:brightness"}
Dimmer TV_Wohnzimmer_Contrast "Contrast" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:contrast"}
Dimmer TV_Wohnzimmer_Sharpness "Sharpness" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:sharpness"}
Number TV_Wohnzimmer_ColorTemperature "ColorTemperature" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:colorTemperature"}
String TV_Wohnzimmer_SourceName "Source Name" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:sourceName"}
Number TV_Wohnzimmer_SourceId "Source ID" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:sourceId"}
Number TV_Wohnzimmer_Channel "Channel" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:channel"}
String TV_Wohnzimmer_ProgramTitle "Program Title" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:programTitle"}
String TV_Wohnzimmer_ChannelName "Channel Name" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:channelName"}
String TV_Wohnzimmer_Url "Url" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:url"}
Switch TV_Wohnzimmer_StopBrowser "Stop Browser" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:stopBrowser"}
Switch TV_Wohnzimmer_Power "Power" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:power"}
Switch TV_Wohnzimmer_ArtMode "Art Mode" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:artMode"}
String TV_Wohnzimmer_SourceApp "Source App" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:sourceApp"}
String TV_Wohnzimmer_KeyCode "Key Code" (gTV_Wohnzimmer) {channel="samsungtv:tv:Wohnzimmer:keyCode"}
Dimmer TV_Schlafzimmer_Volume "Volume" <soundvolume> (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:volume"}
Switch TV_Schlafzimmer_Mute "Mute" <soundvolume_mute> (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:mute"}
Dimmer TV_Schlafzimmer_Brightness "Brightness" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:brightness"}
Dimmer TV_Schlafzimmer_Contrast "Contrast" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:contrast"}
Dimmer TV_Schlafzimmer_Sharpness "Sharpness" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:sharpness"}
//Number TV_Schlafzimmer_ColorTemperature "ColorTemperature" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:colorTemperature"}
String TV_Schlafzimmer_SourceName "Source Name" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:sourceName"}
//Number TV_Schlafzimmer_SourceId "Source ID" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:sourceId"}
String TV_Schlafzimmer_Channel "Channel" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:channel"}
String TV_Schlafzimmer_ProgramTitle "Program Title" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:programTitle"}
//String TV_Schlafzimmer_ChannelName "Channel Name" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:channelName"}
String TV_Schlafzimmer_Url "Url" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:url"}
Switch TV_Schlafzimmer_StopBrowser "Stop Browser" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:stopBrowser"}
Switch TV_Schlafzimmer_Power "Power" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:power"}
//Switch TV_Schlafzimmer_ArtMode "Art Mode" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:artMode"}
String TV_Schlafzimmer_SourceApp "Source App" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:sourceApp"}
String TV_Schlafzimmer_KeyCode "Key Code" (gTV_Schlafzimmer) {channel="samsungtv:tv:Schlafzimmer:keyCode"}
/* KeyCodes:
Can be found here (somewhat): https://github.com/openhab/openhab1-addons/wiki/Samsung-TV-Binding
GUIDE
RETURN
EXIT
VOLUP
VOLDOWN
MUTE
POWER
CHUP
CHDOWN
CH_LIST
REC
PLAY
PAUSE
REWIND
LEFT
RIGHT
ENTER
RED
YELLOW
SOURCE
SUB_TITLE
TOOLS
Soure-Apps:
Prime Video
Netflix
artMode
Apple TV
Disney+
Tubi
Enjoy!
Kind regards,
Ralph…
