Hi!
This is nothing special, but maybe will be useful for someone.
This is a clickable button with image to play radio stream to be used with Squeezebox players.
The advantage of this button is that it converts radio stream into URI directly (on-the-fly) from habpanel so it makes it very easy and quick to configure any radiostation directly from Habpanel.
Example look:
How to:
- Create converturi.js file directly in ‘html’ directory with the following:
angular.module('encodeuri', []).filter('encodeuri', function() {
return function(input) {
return encodeURIComponent(input);
- Add ‘StreamURIitem’ item (and others if you need) to your .items
String StreamURIitem
String StreamLogoItem
String StreamNameItem
- Make rule e.g. playstream.rules and place it into ‘rules’ directory. Don’t forget to edit ‘Your_Squeezebox_Player_PlayPause’ to your Squeezebox player PlayPause channel item. Also if you have item different than StreamURIitem then edit it here.
rule "Squeezebox Radio Playstream"
Item StreamURIitem received update
sendHttpGetRequest(StreamURIitem.state.toString)
Your_Squeezebox_Player_PlayPause.sendCommand(ON)
- Import widget to Habpanel
Squeezebox_PlayStream.widget.json (4.1 KB) - Add widget and configure it following embeded description.
Enjoy!
