Hello everyone. I am trying to create a custom widget for HABpanel that is basically two widget combined. I will explained my final goal first and then expose my first problem.
I cant now control my blinds with a slider for the vertical position and a knob for the orientation of the slats.
That’s OK but I would like to combine these two functions into one widget. I use the knob with a range between 90° and 180° because it is the way it physically works so it is really convenient to know how it is. The problem as you can see is that 75% of the space is wasted and it is complicated to manipulate on a touch device like a tablet.
On other this that I would like to achieve is making use of the ‘moving’ KNX object to disable the widget when the blind is moving.
TL;DR;
The first thing I fail to achieve is to create a custom vertical slider. As soon as I put the vertical option to true the slider starts to behave strangely. My question is then, how I can get the code of existing widgets in HABpanel in order to have a starting point to work with?
Thank you !
