Almost tuned:
My items file
Switch DaikinACUnit_Power "Включить" { channel="daikin:ac_unit:192_168_108_91:power" }
Number DaikinACUnit_SetPoint "Температура [%.0f °C]" { channel="daikin:ac_unit:192_168_108_91:settemp" }
String DaikinACUnit_Mode "Режим" <ac_mode> { channel="daikin:ac_unit:192_168_108_91:mode" }
String DaikinACUnit_Fan "Скорость" <fan> { channel="daikin:ac_unit:192_168_108_91:fanspeed" }
Number DaikinACUnit_IndoorTemperatureF "Внутри [%.1f °C]" { channel="daikin:ac_unit:192_168_108_91:indoortemp" }
Number DaikinACUnit_OutdoorTemperatureF "Снаружи [%.1f °C]" [ "CurrentTemperature" ] { channel="daikin:ac_unit:192_168_108_91:outdoortemp" }
Group gThermostat "Кондиционер Зал" [ "Thermostat" ]
Number ThermostatCurrentTemp "Текущая температура Зал" (gThermostat) [ "CurrentTemperature" ]
Number ThermostatTargetTemperature "Установленная темература Зал" (gThermostat) [ "homekit:TargetTemperature" ]
String ThermostatHeatingCoolingMode (gThermostat) [ "homekit:TargetHeatingCoolingMode" ]
String ThermostatHeatingCoolingCurMode (gThermostat) [ "homekit:CurrentHeatingCoolingMode" ]
My rule file
rule "Thermostat1-Power"
Item DaikinACUnit_Power changed or
Item DaikinACUnit_Mode changed
logInfo("Thermostat Zal", "openHAB Power. Info. Status: " + DaikinACUnit_Power.state.toString);
logInfo("Thermostat Zal", "openHAB Power. Info. Mode openHAB: " + DaikinACUnit_Mode.state.toString);
logInfo("Thermostat Zal", "openHAB Power. Info. Mode HomeKit: " + ThermostatHeatingCoolingMode.state.toString);
if (DaikinACUnit_Power.state.toString == "ON") {
if (DaikinACUnit_Mode.state.toString == "AUTO") {
if (ThermostatHeatingCoolingMode.state.toString != "Auto") {
ThermostatHeatingCoolingMode.sendCommand("Auto");
logInfo("Thermostat Zal", "openHAB Power. Set mode HomeKit: Auto");
if (DaikinACUnit_Mode.state.toString == "COLD") {
if (ThermostatHeatingCoolingMode.state.toString != "CoolOn") {
ThermostatHeatingCoolingMode.sendCommand("CoolOn");
logInfo("Thermostat Zal", "openHAB Power. Set mode HomeKit: CoolOn");
if (DaikinACUnit_Mode.state.toString == "HEAT") {
if (ThermostatHeatingCoolingMode.state.toString != "HeatOn") {
ThermostatHeatingCoolingMode.sendCommand("HeatOn");
logInfo("Thermostat Zal", "openHAB Power. Set mode HomeKit: HeatOn");
if (DaikinACUnit_Mode.state.toString == "DEHUMIDIFIER") {
if (DaikinACUnit_Mode.state.toString == "FAN") {
if (DaikinACUnit_Power.state.toString == "OFF") {
if (ThermostatHeatingCoolingMode.state.toString != "OFF") {
ThermostatHeatingCoolingMode.sendCommand("Off");
logInfo("Thermostat Zal", "openHAB Power. Set mode HomeKit: Off");
rule "Thermostat1-AppleMode"
Item ThermostatHeatingCoolingMode changed
logInfo("Thermostat Zal", "Apple change mode. Info. Status: " + ThermostatHeatingCoolingMode.state.toString);
logInfo("Thermostat Zal", "Apple change mode. Info. Mode power openHAB: " + DaikinACUnit_Power.state.toString);
logInfo("Thermostat Zal", "Apple change mode. Info. Mode openHAB: " + DaikinACUnit_Mode.state.toString);
if (ThermostatHeatingCoolingMode.state.toString == "Off") {
ThermostatHeatingCoolingCurMode.sendCommand("Off");
if (DaikinACUnit_Power.state.toString != "OFF") {
DaikinACUnit_Power.sendCommand("OFF");
logInfo("Thermostat Zal", "Apple change mode. Set power openHAB: OFF");
if (ThermostatHeatingCoolingMode.state.toString == "Auto") {
ThermostatHeatingCoolingCurMode.sendCommand("Cooling");
if (DaikinACUnit_Power.state.toString != "ON") {
DaikinACUnit_Power.sendCommand("ON");
logInfo("Thermostat Zal", "Apple change mode. Set power openHAB: ON");
if (DaikinACUnit_Mode.state.toString != "AUTO" && DaikinACUnit_Mode.state.toString != "DEHUMIDIFIER" && DaikinACUnit_Mode.state.toString != "FAN") {
DaikinACUnit_Mode.sendCommand("AUTO");
logInfo("Thermostat Zal", "Apple change mode. Set mode openHAB: AUTO");
if (ThermostatHeatingCoolingMode.state.toString == "HeatOn") {
ThermostatHeatingCoolingCurMode.sendCommand("Heating");
if (DaikinACUnit_Mode.state.toString != "HEAT") {
DaikinACUnit_Mode.sendCommand("HEAT");
logInfo("Thermostat Zal", "Apple change mode. Set mode openHAB: HEAT");
if (ThermostatHeatingCoolingMode.state.toString == "CoolOn") {
if (DaikinACUnit_Mode.state.toString != "COLD") {
DaikinACUnit_Mode.sendCommand("COLD");
logInfo("Thermostat Zal", "Apple change mode. Set mode openHAB: COLD");
rule "Thermostat1-InTemp"
Item DaikinACUnit_IndoorTemperatureF changed
logInfo("Thermostat Zal", "openHAB set temp in room. Info. Temp: " + DaikinACUnit_IndoorTemperatureF.state.toString);
ThermostatCurrentTemp.sendCommand(DaikinACUnit_IndoorTemperatureF.state.toString);
rule "Thermostat1-Temp"
Item DaikinACUnit_SetPoint changed
logInfo("Thermostat Zal", "openHAB set temp. Info. Temp: " + DaikinACUnit_SetPoint.state.toString);
logInfo("Thermostat Zal", "openHAB set temp. Info. Apple Temp: " + ThermostatTargetTemperature.state.toString);
if (DaikinACUnit_SetPoint.state != ThermostatTargetTemperature.state) {
ThermostatTargetTemperature.sendCommand(DaikinACUnit_SetPoint.state.toString);
logInfo("Thermostat Zal", "openHAB set temp. New Apple Temp: " + DaikinACUnit_SetPoint.state.toString);
rule "Thermostat1-AppleTemp"
Item ThermostatTargetTemperature changed
logInfo("Thermostat Zal", "Apple set temp. Info. Temp: " + ThermostatTargetTemperature.state.toString);
logInfo("Thermostat Zal", "Apple set temp. Info. openHAB Temp: " + DaikinACUnit_SetPoint.state.toString);
if (ThermostatTargetTemperature.state != DaikinACUnit_SetPoint.state) {
DaikinACUnit_SetPoint.sendCommand(ThermostatTargetTemperature.state.toString);
logInfo("Thermostat Zal", "Apple set temp. New openHAB Temp: " + ThermostatTargetTemperature.state.toString);
rule "Thermostat1-Start"
System started
logInfo("Thermostat Zal", "Boot set params. Info. Status openHAB: " + DaikinACUnit_Power.state.toString);
logInfo("Thermostat Zal", "Boot set params. Info. Mode openHAB: " + DaikinACUnit_Mode.state.toString);
logInfo("Thermostat Zal", "Boot set params. Info. Set Temp openHAB: " + DaikinACUnit_SetPoint.state.toString);
logInfo("Thermostat Zal", "Boot set params. Info. Inroom Temp openHAB: " + DaikinACUnit_IndoorTemperatureF.state.toString);
logInfo("Thermostat Zal", "Boot set params. Set mode HomeKit: Auto");
logInfo("Thermostat Zal", "Boot set params. Set mode HomeKit: CoolOn");
logInfo("Thermostat Zal", "Boot set params. Set mode HomeKit: HeatOn");
logInfo("Thermostat Zal", "Boot set params. Set mode HomeKit: Off");
logInfo("Thermostat Zal", "Boot set params. New Apple Temp: " + DaikinACUnit_SetPoint.state.toString);
I can control Daikin from openHAB, iPhone and Siri.
One problem left:
I can not control temperature from apple app(From Siri I can).
What can be a problem?
