This is a solution to a need for a day status update on Things as well as some important temperatures.
Prerequisites:
- Mail Binding with a SMTP thing created
- Group for items that indicate thing status
- Group for items that reflect important temperatures
Steps:
- enable your Mail Binding and add a SMTP thing. Example below will have mail:smtp:YOURSMTPTHING
- Create a Group named GroupStatus and add the Status Items that you wish to receive the report on.
- Create a Group named GroupTempReport and add the temperature Items that you wish to receive the report on.
Here is the Rule that will set the Status Item to ON or OFF based on the status of the Thing you want to track.
In this case the
- Thing is mqtt:topic:TasmotaColdStorage
- Item is a switch named ColdStorageStatus All items need to be Switches for this config. You could also set the item to a string to indicate “ONLINE” or “OFFLINE” but this example would need to be modified to work.
triggers:
- id: "1"
configuration:
thingUID: mqtt:topic:TasmotaColdStorage
type: core.ThingStatusChangeTrigger
conditions: []
actions:
- inputs: {}
label: GetColdStorageStatus
configuration:
type: application/vnd.openhab.dsl.rule
script: >
var thingStatusInfo =
getThingStatusInfo("mqtt:topic:TasmotaColdStorage")
if ((thingStatusInfo !== null) && (thingStatusInfo.getStatus().toString() == "ONLINE")) {
logInfo("ThingStatus", "TasmotaColdStorage is online.")
ColdStorageStatus.postUpdate(ON)
} else {
logError("ThingStatus", "TasmotaColdStorage is offline or doesn't exist.")
ColdStorageStatus.postUpdate(OFF)
type: script.ScriptAction
Here is the Rule for the Daily Report
triggers:
- id: "1"
configuration:
time: 05:00
type: timer.TimeOfDayTrigger
conditions: []
actions:
- inputs: {}
configuration:
script: >-
logInfo("NrCronOut Daily0530", "Triggered")
var String message = "\n"
val report1 = GroupTempReport.allMembers.map[name + ": " + state.format("%s")].join("\n")
if (! GroupStatus.allMembers.filter([state != ON]).empty) {
val report = GroupStatus.allMembers.filter([state != ON]).map[
].join("\n")
message = message + " Openhab Items Offline:\n" + report+ "\n\n" + " Openhab Temperatures:\n" + report1
} else {
message = message + " All items Online" + " Openhab Temperatures:\n" + report1
logInfo("Status Update:", "Message: [{}]", message)
//getActions("mail","mail:smtp:YOURSMTPTHING").sendMail("YOUREMAIL@SOMEWHERE.COM", "OpenHAB Status Message", message)
The report will look something like this.
HVACDownStairsStatus: OFF
OfficeLampStatus: OFF
ColdStorage_FreezerTemperature: 26.1
ColdStorage_DeepFreezerTemperature: -3.9
ColdStorage_RefrigeratorTemperature: 34.6
A big thank you to @denominator and @Oliver2 for assisting me with getting these rules correct.
