does anybody use Danfoss Living Connect LC-13 thermostats?
I’m interested to know if you can still use these devices after the ZWave Binding Update last year.
Hi, I use Popp valves, which I think are nearly the same as the Danfoss ones and yes, I have the latest Zwave binding on OH2.4 stable and it works fine, I think.
//Keller
//Sauna Thermostat
Number Sauna_Danfoss_temp "Heizkörper [%.1f °C]" <thermostat> (gThermostat) {channel="zwave:device:d7de781e:node18:thermostat_setpoint_heating"}
Number Sauna_Danfoss_bat "Sauna Thermostat [%d %%]" <battery> (gBattery) {channel="zwave:device:d7de781e:node18:battery-level" }
Switch Sauna "Sauna Raum wird [MAP(Sauna.map):%s]" <vacation>
rule "Saunaraum heizen ein/aus"
Item Sauna received update
switch Sauna.state {
case ON: sendCommand(Sauna_Danfoss_temp,28)
case OFF: sendCommand(Sauna_Danfoss_temp,8)
Thank you very much!
Do you think there’s a difference to the command Sauna_Danfoss_temp.sendCommand(28) for this particular device? Because that’s the syntax I use.
