I’m trying to start the openhab dashing project, but I’m still having the same error. When I try the dashing with the sample project everything starts perfect, but not with the OpenHab project.
user@server:~/dashboard$ dashing start
/usr/local/lib/ruby/gems/2.0.0/gems/backports-3.6.7/lib/backports/std_lib.rb:9:inrequire': cannot load such file -- data_mapper (LoadError) from /usr/local/lib/ruby/gems/2.0.0/gems/backports-3.6.7/lib/backports/std_lib.rb:9:in
require_with_backports’
from /home/jopo/dashboard/lib/settings.rb:1:in<top (required)>' from /usr/local/lib/ruby/gems/2.0.0/gems/backports-3.6.7/lib/backports/std_lib.rb:9:in
require’
from /usr/local/lib/ruby/gems/2.0.0/gems/backports-3.6.7/lib/backports/std_lib.rb:9:inrequire_with_backports' from /usr/local/lib/ruby/gems/2.0.0/gems/dashing-1.3.4/lib/dashing/app.rb:157:in
block in require_glob’
from /usr/local/lib/ruby/gems/2.0.0/gems/dashing-1.3.4/lib/dashing/app.rb:156:ineach' from /usr/local/lib/ruby/gems/2.0.0/gems/dashing-1.3.4/lib/dashing/app.rb:156:in
require_glob’
from /usr/local/lib/ruby/gems/2.0.0/gems/dashing-1.3.4/lib/dashing/app.rb:166:in<top (required)>' from /usr/local/lib/ruby/gems/2.0.0/gems/dashing-1.3.4/lib/dashing.rb:3:in
require’
from /usr/local/lib/ruby/gems/2.0.0/gems/dashing-1.3.4/lib/dashing.rb:3:in<top (required)>' from config.ru:1:in
require’
from config.ru:1:inblock in <main>' from /usr/local/lib/ruby/gems/2.0.0/gems/rack-1.5.5/lib/rack/builder.rb:55:in
instance_eval’
from /usr/local/lib/ruby/gems/2.0.0/gems/rack-1.5.5/lib/rack/builder.rb:55:ininitialize' from config.ru:1:in
new’
from config.ru:1:in<main>' from /usr/local/lib/ruby/gems/2.0.0/gems/thin-1.6.4/lib/rack/adapter/loader.rb:33:in
eval’
from /usr/local/lib/ruby/gems/2.0.0/gems/thin-1.6.4/lib/rack/adapter/loader.rb:33:inload' from /usr/local/lib/ruby/gems/2.0.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:182:in
load_rackup_config’
from /usr/local/lib/ruby/gems/2.0.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:72:instart' from /usr/local/lib/ruby/gems/2.0.0/gems/thin-1.6.4/lib/thin/runner.rb:200:in
run_command’
from /usr/local/lib/ruby/gems/2.0.0/gems/thin-1.6.4/lib/thin/runner.rb:156:inrun!' from /usr/local/lib/ruby/gems/2.0.0/gems/thin-1.6.4/bin/thin:6:in
<top (required)>’
from /usr/local/bin/thin:23:inload' from /usr/local/bin/thin:23:in
