- Platform information: “openhab/openhab:3.4.2-alpine”
Given following code fragment in an ECMA script rule:
var itemName = event.itemName
var item = items.getItem(itemName)
var dttmThen = time.ZonedDateTime.now().minusDays(1)
var minSince = item.history.minimumSince(dttmThen)
var maxSince = item.history.maximumSince(dttmThen)
console.debug("Dump minSince")
console.debug("typeof minSince: ", typeof minSince)
console.debug("minSince: ", minSince)
console.debug("minSince.state: ", minSince.state)
console.debug("minSince.numericState: ", minSince.numericState)
console.debug("minSince.rawState: ", minSince.rawState)
console.debug("minSince.timestamp: ", minSince.timestamp)
I would not expect following output in the logs:
2023-03-29 00:40:30.672 [DEBUG] [cript.ui.calcMinMaxValuesInIntervall] - main:25 : Calculating min/max for Temperature_Alarm
2023-03-29 00:40:30.698 [DEBUG] [cript.ui.calcMinMaxValuesInIntervall] - Dump minSince
2023-03-29 00:40:30.710 [DEBUG] [cript.ui.calcMinMaxValuesInIntervall] - typeof minSince: number
2023-03-29 00:40:30.711 [DEBUG] [cript.ui.calcMinMaxValuesInIntervall] - minSince: 2.24
2023-03-29 00:40:30.711 [DEBUG] [cript.ui.calcMinMaxValuesInIntervall] - minSince.state: undefined
2023-03-29 00:40:30.711 [DEBUG] [cript.ui.calcMinMaxValuesInIntervall] - minSince.numericState: undefined
2023-03-29 00:40:30.711 [DEBUG] [cript.ui.calcMinMaxValuesInIntervall] - minSince.rawState: undefined
2023-03-29 00:40:30.711 [DEBUG] [cript.ui.calcMinMaxValuesInIntervall] - minSince.timestamp: undefined
but rather that minSince is a HistoricItem Object (instead of number) with those properties defined (there is plenty of data in the database for a day).
Default persistency is a mysql database.
