No, of course not, epoch is in UTC.
openHAB converts from UTC to your local zone for display in user-facing UI.
Raw Item state remains UTC.
So to return to what do you want …?
If you want the time in your Item state in local time, you will have to do that in a transformation. Probably JS, so that it can parse the epoch to UTC, find out your local zone, and then convert UTC to local zone, finally adding local zone indicator to the end
If you want to treat the incoming data as non-epoch, again I think you will need a JS transformation. Parse the “epoch” to a datetime, find out the local current offset and apply it, change the zone indicator to local.
Do you think it is also possible to read the epoch, add the value of 2700 (2 hours) and then parse it to datetime? Is this possible out of the box or is also JS needed? How would the transformation look like with the ∩ chain character?
2021-04-18 13:05:09.055 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'calendar-1' failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.actions.ScriptExecution.createTimer(java.time.ZonedDateTime,org.eclipse.xtext.xbase.lib.Procedures$Procedure0) on instance: null in calenda
Any idea to convert the DateTime in the right format for createTimer?
If you want to start the timer when a certain time has come, you need a comparison of 2 dates first and than start a timer for a certain amount of time ( seconds, minutes, hours … )
Here is a good example how to do date comparison:
or more simple:
val startdate = (RolladenControlCalendar_1_start.state as DateTimeType).getZonedDateTime()
if (now.isAfter(startdate)) { do stuff ....for example create a timer...
The documentation is somehow not easy to understand. You’ll only find createTimer(AbstractInstant instant, Procedure procedure): For Datatype AbstractInstant I was not able to find anything that makes sense…
Script execution of rule with UID ‘presence-8’ failed: An error occurred during the script execution: null in presence
I understand the below rule no longer works in OH3 because of datetime changes:
rule "LastMotionOFF"
Item remoteSensors_Ecobee_1_Bedroom_Occupancy changed to OFF or
Item remoteSensors_Ecobee_2_Kitchen_Occupancy changed to OFF
switch LastOccuTime.state {
DateTimeType: {
var DateTime halfHourAgo = now.minusMinutes(30)
var DateTime lastKnownMotion = new DateTime((LastOccuTime.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
if (halfHourAgo.isAfter(lastKnownMotion)) {
LastOccuTime.postUpdate(new DateTimeType(halfHourAgo.toString))
Is this format not the correct use of zonedDateTime?
DateTimeType: {
var ZonedDateTime halfHourAgo = now.minusMinutes(30)
var lastKnownMotion = (LastOccuTime.state as DateTimeType).getZonedDateTime()
LastOccuTime.postUpdate(halfHourAgo.toString())
atleast the ZonedDateTime comparison should be ok now. Not sure about DateTimeType: {…} though, could be obsolete.
I’m also moving to OH3 and I’m stuck with this rule:
rule "Check and Reload ComfoAirQ Homie"
Time cron "0 0/5 * * * ?"
if (vQ_Ventilation_Gateway_Connection_State_Last_Update.state == NULL) {
logInfo("Check and Reload ComfoAirQ Homie", "vQ_Ventilation_Gateway_Connection_State_Last_Update = NULL");
} else ( now.minusMinutes(3).isAfter((vQ_Ventilation_Gateway_Connection_State_Last_Update.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli))
// vEQ_Ventilation_Gateway_Reload_Timer.sendCommand(ON)
logInfo("homie_rules", "Reload Homie Devices")
mqttActions.publishMQTT("homie/zehnderq450gateway/controls/reload/set","true", false)
I get this error:
Script execution of rule with UID 'comfoair-5' failed: An error occurred during the script execution: Could not invoke method: java.time.
chrono.ChronoZonedDateTime.isAfter(java.time.chrono.ChronoZonedDateTime) on instance: 2021-04-27T13:32:00.385453+02:00[Europe/Amsterdam] in comfoair
So I changed zonedDateTime to getZonedDateTime but the error remains. Who can help me?
var Ventilation = (vQ_Ventilation_Gateway_Connection_State_Last_Update.state as DateTimeType).getZonedDateTime()
if (now.minusMinutes(3).isAfter(Ventilation)) {
yes, but also convert from a DateTimeType correctly to a ZonedDateTime() at the same time. You could do it in just one line I suspect but this is my preferred option for more clarity in the rule. ( just my 2 cent on this )
