I cant for the life of me get a datetime field to be compared against now - the latest ive tried is:
var DateTime dateTime = new DateTime((CalendarTimeStart1.state as DateTimeType).calendar.timeInMillis)
if (dateTime.plusMinutes(30).isBefore(now)) {
testend.postUpdate("yer")
else {
testend.postUpdate("nar")
it always ends in the log:
2018-02-18 17:15:02.828 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Calendar Reminder': Could not cast 2018-02-18T17:15:02.827+10:30 to org.eclipse.smarthome.core.library.types.DateTimeType; line 129, column 42, length 19your code goes here
ive tried using
new DateTime((CalendarTimeStart1.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
with same result
Can anyone help?
ultimately I am trying to check that a calendar event’s start time is 60 minutes before “now” so I can create a calendar reminder.
val DateTime CheckTimeStart = new DateTime((CalendarTimeStart1.state as DateTimeType).calendar.timeInMillis)
val DateTime roundedeventstart = CheckTimeStart.minuteOfDay().roundFloorCopy
val DateTime roundednow = now.minuteOfDay().roundFloorCopy
if (roundednow.plusMinutes(60) == roundedeventstart) {
Echo_Living_Room_Remind.sendCommand("You have a calendar event " + CalendarName1.state + " starting in 60 minutes")
I get a warning that getcalendar is deprecated - anyone know what I should be using to get the same result?
This is ultimately doing the job but I have to check the value every minute so it matches the next up calendar event - if anyone can think of a tidier way Id be grateful
Thanks - I thought I had something in there like that before but tried many things and failed - no errors yet will see what happens at the next calendar reminder!
