DateTime List Item
Happy to share my configs.
Widget code I am using:
uid: rlk_datetime_list
tags:
  - marketplace:127967
props:
  parameters:
    - description: Label for the widget
      label: Label
      required: false
      type: TEXT
    - context: item
      description: An item to control
      label: Item
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Oct 5, 2022, 3:55:27 PM
component: oh-input-item
  inputmode: text
  label: =props.label
  outline: true
  sendButton: true
  subtitle: "=(items[props.item].displayState) ? items[props.item].displayState : items[props.item].state"
  title: =props.label
  type: datetime-local
Test page using the widget
  label: Test
blocks:
  - component: oh-block
    config: {}
    slots:
      default:
        - component: oh-grid-row
          config: {}
          slots:
            default:
              - component: oh-grid-col
                config: {}
                slots:
                  default:
                    - component: oh-toggle-card
                        item: testswitch
          config: {}
          slots:
            default:
                config: {}
                slots:
                  default:
                    - component: oh-list-card
                      config: {}
                      slots:
                        default:
                          - component: widget:rlk_datetime_list
                              label: Endzeitpunkt
                              item: HomematicIP_Thermostat_Badezimmer_Profile_Override_EndDateTime
masonry: null
grid: []
canvas: []
Item description
DateTime                    HomematicIP_Thermostat_Badezimmer_Profile_Override_EndDateTime        "Profil Soll Ende [%1$td.%1$tm.%1$tY %1$tH:%1$tM]"              <calendar>       (gBadezimmerThermostat)        ["Point","None"]                 {stateDescription="" [pattern="%1$td.%1$tm.%1$tY %1$tH:%1$tM"]}
There’s nothing in the widget config that can change this. Frankly, the only reason that I published this as a widget to the marketplace was to make writing a tutorial easier. It’s a standard oh-input-item. All I did was set the type to datetime-local which is what causes it to render the date time picker. I also set the sendButton property to true.
That’s it. There’s nothing else.
This is a really lame custom widget. There’s nothing unique here. There’s nothing you couldn’t do yourself. All I did was set two of the documented oh-input-item properties so it shows the date time picker.
There might be something that can be done by OH (please file an issue on the openhab-webuis repo) but from what I saw, what actually renders that date time picker is not MainUI, it’s not even F7. As far as I can tell, it’s the web browser itself. So if it doesn’t work I’m not sure there’s much OH can do about it. There certainly isn’t anything I can do about it from the widget.
Any idea / workaround how I could enter a datetime? I have a lot of thermostats where I want to use a datetime with proper picker. Having a standalone widget would be somehow problematic.
Any workaround idea? Via popup using the standalone widget does not work as well (yet).
I doubt it. I suppose you could try to implement a whole new widget from scratch, if that’s even possible. But whether you put it in a pop-up or anything else, as long as you are using an oh-input-item what you see is what you get.
Just an FYI, I have the same problem, the stand alone widget does show the send button, but no such button on the list. So I can only update the item through the standalone widget and not the list.
